route depending on port locally or on an router on a stick
ino
i have a 2960 with routing enabled i would like it to route traffic like port 80, 433 ...
but send all other traffic to an other router / firewall  (isr c1111) for routing
can this be done in some way?
so
pc1 vlan 1
pc2 vlan 2
if pc1 calls a http side on pc2 its routed on the switch (thats working)
but lets say pc1 want to ssh in to pc2 in that case it should be routed first to the c1111 (dont know how to set up)
the idea is to have just some basic acl on the switch
and a more complex on the c1111
balaji.bandi
check what Liicense you on switch. below high level guide for you to work on :
config t
ip access-list extended SSH_PBR
permit tcp PC1-IP(x.x.x.x) PC2-IP(y.y.y.y_ any eq 22
route-map SSH_NEXTHOP permit 10
match ip address SSH_PBR
set ip next-hop z.z.z.z
interface Gig0/0
ip policy route-map SSH_NEXTHOP
end
BB
balaji.bandi
config t
interface Gig0/0
end
BB
ino
thank you
that was relative pain less
was need to change the "sdm prefer" setting and reload the switch prior but fortunately i got a warning in the cli to do so
ip access-list extended TEST
permit ip any host 10.0.10.10
route-map TEST permit 10
match ip address TEST
set ip next-hop 10.0.0.1
interface Vlan103
ip address 10.0.30.1 255.255.255.0
ip policy route-map TEST
PS C:\Users\sa> tracert 10.0.10.10
Tracing route to dc.mydomain.com [10.0.10.10]
over a maximum of 30 hops:
1 2 ms 1 ms 1 ms 10.0.30.1
2 <1 ms <1 ms <1 ms c1111.mydomain.com [10.0.0.1]
3 1 ms 1 ms 1 ms c2961.mydomain.com [10.0.0.2]
4 <1 ms <1 ms <1 ms dc.mydomain.com [10.0.10.10]
Trace complete.
PS C:\Users\sa> tracert 10.0.10.20
Tracing route to ca.mydomain.com [10.0.10.20]
1 <1 ms 1 ms 1 ms 10.0.30.1
2 <1 ms <1 ms <1 ms ca.mydomain.com [10.0.10.20]
