Route Leaking between two VRF on the same router (Cisco IOS)
AndreaQuerci
Hi guys,
it's my first time with the route leaking feature and I tried to configure it on my LAB via EVE-NG, but unfortunately it didn't work. I attached a screenshot about my LAB.
my little enterprise network has been subdivided in three different vrfs (10_OFFICE_NET, 20_IT_NET, 11_MNGNT_NET) and on the core routers I configured another vrf called CORE. all of then must be in communication and to reach this goal I configured the core routers (for now just the CSW01) following an hub and spoke logic, the CORE vrf must be the hub vrf and the other ones must be the spokes.
I want to give you an example about I want to do. if the PC01 wants to reach internet (it's behind the ASA firewall) it must be reach the core routers via OSPF and from there the flow must be route-leaked via BGP from the source vrf (10_OFFICE_NET) to the CORE vrf, and finally reach the destination.
following you can see the CSW01 cofniguration:
CSW01#show run
Building configuration...
Current configuration : 4208 bytes
! Last configuration change at 22:14:42 EET Sat Oct 26 2019
version 15.2
service compress-config
hostname CSW01
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EET 2 0
ip vrf 10_OFFICE_NET
rd 65000:10
route-target export 65000:10
route-target import 65000:254
ip vrf 11_MNGNT_NET
rd 65000:11
route-target export 65000:11
route-target import 6500:254
ip vrf 20_IT_NET
rd 65000:20
route-target export 65000:20
ip vrf CORE
rd 65000:254
route-target export 6500:254
route-target import 6500:10
route-target import 6500:20
route-target import 6500:11
no ip domain-lookup
ip cef
no ipv6 cef
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface Loopback10
ip vrf forwarding 10_OFFICE_NET
ip address 172.31.10.3 255.255.255.255
interface Loopback11
ip vrf forwarding 11_MNGNT_NET
ip address 172.31.11.3 255.255.255.255
interface Loopback20
ip vrf forwarding 20_IT_NET
ip address 172.31.20.3 255.255.255.255
interface Loopback254
ip vrf forwarding CORE
ip address 172.31.254.3 255.255.255.255
interface Ethernet0/0
interface Ethernet0/1
switchport access vlan 90
switchport mode access
interface Ethernet0/2
interface Ethernet0/3
no switchport
no ip address
interface Ethernet0/3.10
encapsulation dot1Q 10
ip address 172.16.10.18 255.255.255.252
ip ospf network point-to-point
interface Ethernet0/3.11
encapsulation dot1Q 11
ip address 172.16.11.18 255.255.255.252
interface Ethernet0/3.20
encapsulation dot1Q 20
ip address 172.16.20.18 255.255.255.252
interface Ethernet1/0
switchport mode trunk
interface Ethernet1/1
no switchport
no ip address
interface Ethernet1/1.10
ip address 172.16.10.2 255.255.255.252
interface Ethernet1/1.11
ip address 172.16.11.2 255.255.255.252
interface Ethernet1/1.20
ip address 172.16.20.2 255.255.255.252
interface Ethernet1/2
no switchport
no ip address
interface Ethernet1/3
interface Vlan10
ip address 172.16.10.21 255.255.255.252
interface Vlan11
ip address 172.16.11.21 255.255.255.252
interface Vlan20
ip address 172.16.20.21 255.255.255.252
interface Vlan90
ip address 172.16.90.1 255.255.255.240
vrrp 90 ip 172.16.90.3
vrrp 90 priority 200
router ospf 10 vrf 10_OFFICE_NET
router-id 172.31.10.3
redistribute bgp 65000 subnets
network 172.16.0.0 0.0.255.255 area 0
router ospf 20 vrf 20_IT_NET
router-id 172.31.20.3
router ospf 11 vrf 11_MNGNT_NET
router-id 172.31.11.3
router bgp 65000
bgp log-neighbor-changes
address-family ipv4 vrf 10_OFFICE_NET
bgp router-id 172.31.10.1
redistribute ospf 10
exit-address-family
address-family ipv4 vrf 11_MNGNT_NET
bgp router-id 172.31.11.1
redistribute ospf 11
exit-address-family
address-family ipv4 vrf 20_IT_NET
bgp router-id 172.31.20.1
redistribute ospf 20
exit-address-family
address-family ipv4 vrf CORE
bgp router-id 172.31.254.1
redistribute connected
redistribute static
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route vrf CORE 0.0.0.0 0.0.0.0 172.16.90.13
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
privilege level 15
logging synchronous
no login
transport input telnet
end
the redistribution from OSPF to BGP (10_OFFICE_NET, 20_IT_NET, 11_MNGNT_NET vrfs) and from the static routing to BGP (CORE vrf) works, but the route leaking it doesn't work, and of course also the redistribution between the BGP to OSPF.
someone can help me to troubleshoot the problem?
p.s.:
I studied the route leaking feature (vrf lite) from this CCIE blog:
https://ccieblog.co.uk/mpls/inter-vrf-routing
at first glance, I don't see any export maps under VRFs. Typically, you would need to configure a route map with a matching access list for the routes you want to leak (and set the route target community, which the is used as the target for the route import). So, as an example, let's say you want to import the routes matched in the route map VRF_10_TO_VRF_11 from VRF_10 into VRF11, you would needto configure something like this:
route-map VRF_10_TO_VRF_11 permit 10
match ip address 1
set extcommunity rt 4:4 additive
rd 65000:10
export map VRF_10_TO_VRF_11
ip vrf 11_MNGNT_NET
rd 65000:11
route-target import 4:4
