Mini-IOS
gowdakssujan
Level 2
Level 2
How does mini-IOS helps in boot process??
How/why do router enter/load into mini-IOS??
balaji.bandi
here is the good explanation for reference :
Mini-IOS
Mini-IOS is a fallback utility that contains a stripped down version of IOS. This is used in critical situations where IOS image in flash is not found. Mini-IOS contains only IP code that allows you to load IOS from other resources such as TFTP Server. Cisco IOS mode used by this stripped down IOS utility known as RXBOOT mode.
https://www.computernetworkingnotes.com/ccna-study-guide/cisco-router-booting-process-explained-with-examples.html
BB
