Route-map and match command to different things
Matt qomat
I wonder if anyone can help with my concern. Let's say we have 100 subnets. I want to prepend only half of them. So I'll build a route-map applyed on BGP neighbor matching the prefix-list of all those subnets and setting a prepend. But how to prepend only half of them? doing match one prefix-list and than match the other I think has and in between so set prepend will match both. Please help
7 Replies 7
royalblues
Level 10
Level 10
Create a seperate prefix-list for the subnets u need to do as prepend and configure a route-map
something like this
R1
router bgp 1
no synchronization
bgp log-neighbor-changes
network 1.0.0.0
network 2.0.0.0
neighbor 10.10.10.2 remote-as 2
neighbor 10.10.10.2 prefix-list out out
neighbor 10.10.10.2 route-map prepend out
no auto-summary
ip prefix-list prependlist seq 10 permit 1.0.0.0/8
route-map prepend permit 10
match ip address prefix-list prependlist
set as-path prepend 1 1 1 1
route-map prepend permit 20
R2
router bgp 2
no synchronization
neighbor 10.10.10.1 remote-as 1
no auto-summary
R2#sh ip bgp
BGP table version is 13, local router ID is 10.10.10.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>1.0.0.0 10.10.10.1 0 0 1 1 1 1 1 i
*> 2.0.0.0 10.10.10.1 0 0 1 i
Narayan
So if you have let say 3 subnets and you want them all advertise but only two of them to prepand. Based on your notes I thought about
set as-path prepend 1111
match ip address prefix-list 3rdsubnet
So that should prepned all the subnets from prependlist and send clear 3rd, right?
No need to match anything under the second route map
will do .. include only the subnets that u want to have as path prepends as part of prefix-lists
Narayan
Can the same be achieved just using an access list in the route-map like
match ip address 3
ip access-list 3 permit X.X.X.X
if we dont have to add anything under route-map prepend permit 20 then why are doing this command exactly
thanks in advance
subra
Subra
If you dont add the 2md route-map command, it will only send out the prefixes that match the list and filter everythign else
The 2nd map actually will ensure all the other prefixes which are not to be prepended to be matched and advertised.
use of prefix-lists are more beneficial as it uses CIDR notation
Narayan
But I also have subnets that I do not want to advertise. So its not like all other will not be prepended. I guess i do need match those that will not be prepended so that site act as originator.
Yes thats correct..
Create a sperate prefix-list and match them under the 2nd route-map but do not add any set command
Narayan
