Route-map MY-LOCAL-POLICY
insccisco
Guys,
can you please help understand exactly what the following code means:
route-map MY-LOCAL-POLICY permit 10
match ip address 150
set ip next-hop 75.127.231.25
set interface Null0
Especially, what does the Null interface do?
Mohamed Sobair
Level 7
Level 7
The PBR matches the Datagrams recieved by the Interface and forward it based on the routing policy.
Your config means, If packet hits an interface and matches ACL 150 , then forward the packet and sets the next hop to be (75.127.231.25) , However, If the Next hop (75.x.x.x) is not reachable, then Set the next hop of the packet to (Null0 interface) , In other word black hole or drop the traffic.
Mohamed
6 Replies 6
Istvan_Rabai
Level 7
Level 7
Hi Angel,
These are the route-map statements for policy routing and applied together with the "ip policy route-map MY-LOCAL-POLICY" on an interface for policy-routing incoming traffic that may override the routing table.
This route-map says:
If the incoming packet matches on ACL 150 then it should be routed to next-hop 75.127.231.25.
Else the packet should be routed using the normal routing table.
The ip next-hop must be a neighbor router on a directly connected link.
What I don't understand:
If the writer of this route-map wants to route traffic to a next-hop router, why would he want to drop it: this is what the "set interface Null0" does.
So either "set ip next-hop 75.127.231.25" or "set interface Null0" is redundant in the config.
Cheers:
Istvan
Hi Istvan,
This code is from a single router with 2 ISP. The router is doing failover meaning that if ISP1 goes down, it will re-route the traffic via ISP2.
This code is part of the Object Tracking system. When ISP1 is up, all is normal and the router tracks 2 objects and uses access list 150 for this. The idea is to always "track" those 2 objects only via ISP1. When ISP2 is up, the objects should not be tracked using ISP2, so I assume that the "set interface Null0" does this.
So, from your explanation I get that the these statements are read in order. So when the router is going out to the internet using ISP2, the statement "set ip nex-hop 75.127.231.25" will be ignored but then is dropped at the next statement "set interface Null0" ... right?
Mohamed Sobair
Level 7
Level 7
Mohamed
Great stuff Mohamed. This is exactly the understanding I was looking for.
Now I have one more bit of understanding to do... the code
set interface Null0
is called by
ip local policy route-map MY-LOCAL-POLICY
and the access-list 150 is
access-list 150 permit icmp any host 66.66.66.66 echo
access-list 150 permit icmp any host 4.2.2.2 echo
I want to know in what direction this is applied? when the statement "ip local policy route-map MY-LOCAL-POLICY" is triggered, in what direction this is supposed to go for it to trigger?
Mohamed Sobair
Level 7
Level 7
The Ip Local-policy route-map MY-LOCAL-POLICY instruct the router to perform PBR locally.
Looking at ur exampl:
It means icmp request from the router detined to (66.66.66.66 & 4.2.2.2) has to be Locally Policed and set the next hop to be 75.127.231.25 or Null0 If the next-hop is not reachable.
This only applies from the router it self, the direction of the traffic is defined by the nexthop on the Policy-map.
Mohamed
great stuff again Mohamed. Thank you very much.
do you have any good links to read on this subject (PBR)?
