Bookmark
Subscribe
851
Router 851 software versions
gimmeshelter
  Hello, I have a question regarding a router 851. I have tryed the configuration from an older post on my 851 router (i need pppoe confing) but It dosent work. I get this "% Invalid input detected at '^' marker." when i try to put this line "no ip dhcp use vrf connected". From what i saw this is because there are diffrent software versions acording to this: http://808techblog.com/netflow/2008/02/ but I dont have a solution.
My question is can I still configurate my router with this configuration: https://supportforums.cisco.com/message/3432601 if it has Version 12.4(15)T6?
This is my router running config:
Paltinis#sh running-config
Building configuration...
Current configuration : 1654 bytes
version 12.4
no service pad
hostname Paltinis
boot-start-marker
boot-end-marker
enable secret 5 $1$T/5A$rNrZUOri4.JHzFBb7vB.21
enable password admins
no aaa new-model
dot11 syslog
no ip dhcp use class
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp pool LAN-Palt
   import all
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   lease infinite
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username admin password 0 admin
archive
log config
  hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username ************* password ***************
ppp ipcp dns request accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 192.168.0.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password admin
login
scheduler max-task-time 5000
end
Paltinis#
The DHCP works fine, but the ppp dont.
Richard Burts
In general I would think that the config should work ok with the different version of IOS code. When there are problems with things not working (especially things as fundamental as ppp) they are likely to be more related to differences in feature set or in licensing than to be about different versions of code.
The main problem that I notice is that interface Fastethernet4 which is your ppp interface is shutdown. Get that interface no shutdown and see what happens.
Rick
Rick
paolo bevilacqua
Take "debug ppp neg" and "debug ppp auth" with "term mon".
Note if you are replacing an ISp router you may need to wait some time with the cricuit off, of have ISP clear any MAC lock or cache.
Richard Burts
Rick
Rick
Great! Thank you it works like a charm. It took me 2 days not to find the problem but i was searching in the wrong direction.
I am glad that we were able to help you. It is one of the great things about this forum that you get other eyes looking at problems and noticing things that you have not yet picked up on. I find that sometimes we are looking very hard expecting a complicated configuration problem when the real issue is so simple that we over look it.
Thank you for using the rating system to mark this question as answered. It makes the forum more useful when people can read a question and can know that an answer was found. Your marking has contributed to this process.
Rick
Rick
