Watch Dog Timeout constantly rebooting my C3845
Maciej Bylica
I have purchased Cisco 3845 and have problems to boot it without problems.
To be more precisely i am getting "Watch Dog Timeout Reset" and box is constantly rebooting itself.
------ log 1 --------------------------------------------
System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Copyright (c) 2006 by cisco Systems, Inc.
System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
Total memory size = 512 MB - DIMM0 = 512 MB, DIMM1 = 0 MB
c3845 platform with 524288 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb40
program load complete, entry point: 0x80010000, size: 0x2212d64
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################################################################################## [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
00042C          0X010D78F3 C3845 motherboard
                0X00280000 OIR memory
                0X00288860 Onboard PVDM2 SIMM
                0X000021B8 Onboard USB
                0X00660670 public buffer pools
                0X0078F000 public particle pools
TOTAL:          0X023D197B
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 36Mb.
Using 7 percent iomem. [36Mb/512Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 3800 Software (C3845-SPSERVICESK9-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 18:36 by prod_rel_team
Image text-base: 0x60011084, data-base: 0x62CE4190
*** Watch Dog Timeout Reset ***
ra = 0x603cd1f0, EPC = 0x603cd1f0
*** BCM 1125 went through a full reset. HT/PCI fabric reset. ***
Here are few steps that i have aleady done to solve this:
1) use different CF with the same result
2) use few IOS  c3845-ipbase-mz.124-18.bin, c3845-ipvoicek9-mz.124-17.bin,
c3845-ipvoicek9-mz.124-22.T.bin, c3845-spservicesk9-mz.124-13c.bin with the same result
3) tried to boot IOS from rommon mode with exactly the same after-effect
4) checked if cookie is okay. Unfortunately i cannot say that the whole cookie is okay, but beginning octets are not FF's.
cookie:
04 ff c1 8b 46 4f 43 31 33 32 38 36 32 4d 52 40
04 2c 41 01 04 c0 46 03 20 00 5c 40 07 42 43 30
88 00 01 8e fa 02 05 03 00 81 00 00 00 00 04 00
09 69 c6 8a 49 50 4d 4e 58 30 30 44 52 41 cb 8c
43 49 53 43 4f 33 38 34 35 2d 4d 42 89 56 30 37
20 d9 02 40 c1 c3 06 00 26 0b d3 90 10 43 00 30
82 49 22 5f 0a 83 01 32 8f 5b c2 8b 46 54 58 31
33 33 31 41 4a 42 42 ff ff ff ff ff ff ff ff ff
Could you please tell me where to look for "Chassis MAC Address" so i can compare? - first octets?
5) tried to upload ios from rommon mode without success. See logs below:
------ log 2 --------------------------------------------
rommon 3 > IP_ADDRESS=192.168.1.5
rommon 4 > IP_SUBNET_MASK=255.255.255.0
rommon 5 > DEFAULT_GATEWAY=192.168.1.1
rommon 6 > TFTP_SERVER=192.168.1.10
rommon 7 > TFTP_FILE=c3825-spservicesk9-mz.124-24.T.bin
rommon 8 > tftpdnld
          IP_ADDRESS: 192.168.1.5
      IP_SUBNET_MASK: 255.255.255.0
     DEFAULT_GATEWAY: 192.168.1.1
         TFTP_SERVER: 192.168.1.10
           TFTP_FILE: c3825-spservicesk9-mz.124-24.T.bin
             GE_PORT: Ge0/0
     TFTP_MEDIA_TYPE: Copper
       GE_SPEED_MODE: Auto
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash: will be lost!
Do you wish to continue? y/n:  [n]:  y
Mac Address: 0026.0bd3.9010
Receiving c3825-spservicesk9-mz.124-24.T.bin from 192.168.1.10 !!!!!!!!!!!!!!!!!!!!!!!!
File reception completed.
TFTP flash copy: Invalid file header, copy terminated.
         Reason: Wrong target platform OR corrupt file.
6) Removing PVDMs did not change anything
I have no idea how to solve this.
Could anyone give me advice.
Maciej
2 Accepted Solutions
Broken faulty router, that Cisco will replace if under support contract.
if you are complaining about your 3845 rebooting all the time, why are you trying to load a 3825 ios?  Get the correct ios and try again.
It's got nothing to do with the IOS.  If you look at the bootup process after the router passes the bootstrap the router crashes.  It's a hardware fault.
18 Replies 18
Reza Sharifi
If this is new router, most likely you have a hardware problem.  Open a ticket with TAC and RMA the router
Here is more info regarding the error message:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a00800f67db.shtml
Thanks Reza for prompt answer.
This is second hand router
Btw: your link does not work.
If it is second hand then I assume you don't have a service contract to replace it.  Since the router keep rebooting, try using the following link to see if you can break in to the router and load a different IOS.
http://www.cisco.com/en/US/products/hw/routers/ps274/products_password_recovery09186a0080094774.shtml
I was trying to load different IOS several times but still Cisco was rebooting itself.
As i stated previously Cisco was originaly shipped with c3845-spservicesk9-mz.124-13c.bin, but i was trying c3845-ipbase-mz.124-18.bin, c3845-ipvoicek9-mz.124-17.bin, c3845-ipvoicek9-mz.124-22.T.bin as well
Of course that was only possible from Rommon mode (from few CF's cards or tftp), because watchdog prevents from giving me prompt.
Regarding "Troubleshooting Watchdog Timeouts" page it is probably software watchdog timeout (i pasted all the output).
If you could get to Rommon mode, you could also use Xmodem to try to load a new IOS.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
I was trying to upload IOS to Cisco with confreg 0x3922 but at the end got error that the file cannot be opened.
Ready to receive file c3845-ipbase-mz.124-18.bin ...
Format: All system sectors written. OK...
Format: Operation completed successfully.
Format of flash: complete
open(): Open Error = -13
create a file failed...err code = -1
rommon 2 >
I need to check another CF card tomorrow and give us an update here.
There is no need to use xmodem with modern routers.
You can do tftpdnld -r to load and boot the image without writing to flash.
However from previous posts I suspect you have faulty hardware.
Is there any way to find what exactly is out of order?
Dont' you think that cookie might be corrupted?
Paulo, unfortunately that Cisco is not under any support contract
Don't you think that cookie might be responsible for such Cisco behaviour?
No.
You can buy a support contract at any time.
lsharrah
