Router bgp network /16 not advised
Marco Bisignano
Hi all, I have the following configuration:
interface GigabitEthernet1/0
description ita_internal
ip address 10.39.1.1 255.255.255.0
negotiation auto
no keepalive
no cdp enable
interface GigabitEthernet2/0
description esp_iop
ip address 10.39.255.1 255.255.255.252
negotiation auto
no keepalive
no cdp enable
service-policy input Police
service-policy output ShapeOutgoing
router bgp 57.1
no synchronization
bgp log-neighbor-changes
bgp dampening
network 10.39.0.0
network 10.39.0.0 mask 255.255.0.0
neighbor 10.39.255.2 remote-as 52.1
neighbor 10.39.255.2 ebgp-multihop 2
neighbor 10.39.255.2 next-hop-self
neighbor 10.39.255.2 advertisement-interval 2
neighbor 10.39.255.2 soft-reconfiguration inbound
My neighbor is up, but my problem is that my network 10.39.0.0 is not advised to my neighbor, on "sh ip bgp 10.39.0.0" I receive:
% Network not in table
If I put "network 10.39.1.0 mask 255.255.255.0" this is advised, but I need 10.39.0.0 with mask /16; what's wrong with this configuration ?
Harold Ritter
Hi Marco,
The network statement requires a route with the exact same mask in the routing table in order for the route to get originated in BGP. In general, it is recommended to have a static route pointing to null0 to originate the aggregated route.
ip route 10.39.0.0 255.255.0.0 null0
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
9 Replies 9
Harold Ritter
Hi Marco,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I came to read about black hole configuration that will drop/discard all packet destined to configured subent.So I confused a little bit that In this scenarion will it discard the packet which is destined to 10.39.0.0?
The example in this thread is not to drop traffic but to allow BGP to advertise the summary route.
The assumption is that the router advertising the summary route also has the more specific routes that are part of the summary route.
So neighboring routers receive an advertisement for the summary route and send any traffic destined for networks within that summary route to the advertising router. This router then has the more specific network entries in it's routing table and because a more specific route is always used the packet is forwarded to the correct next hop.
If there is no more specific route though then yes, the packet would be dropped so you do need to be careful when using the above method to advertise summary routes.
Jon
satya mothukuri
I too had same issue. After adding the route to Null0, it was showing in routing table. It should work. try that.
Inderjeet Singh
Network command requies exact masked route to be learned from IGP.. as mentioned by Harold, you can enter a static with /16 mask pointing to "null"
Umesh Shetty
Hi Marco,
As suggested by othets you need a route for the 10.39.0.0 in the routing table of the local router as a connected interface ,learnt through other routing protocols or static. As per you router config you only have 10.39.1.0 configured on Gig 0/0 interface. If you add a static route for subnet 10.39.0.0/16 pointing to null0 and advertise it in BGP all traffic for this /16 subnet will be directed to this router unless other routers in your network are originating a better or a more specific route to a subset of this /16 subnet. But please note that since the static route is pointing to null0 interface all traffic (other that 10.39.1.0 which is actually available on this router)  that comes to this router will be dropped. If this is just a test lab where you are testing BGP this is fine. If this is a production setup where you have 10.39.0.0/16 used in your network you must actually point your static route on your router to towards the interface through which these networks are reachable so that when traffic arrives to this router ( because of the BGP advertisement) this router can direct the traffic towards these subnets.
Umesh Shetty
Umesh,
Generally, the more specific routes are learned via the IGP.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Harold,
Yes thats generally the case, I just wanted to make sure if thats how it is here as well. If its not this may cause a traffic black hole.
Umesh
Marco Bisignano
Thank you all, as you suggested, it was a static route problem.
Regards.
