Router Configuration HELP
hx2
My router doesn't seem to be passing traffic. I have a static route set, but it's not working. I'm new to router configuration, can someone help?
9 Replies 9
scottmac
Level 10
Level 10
Post your (sanitized) config, the router model, and the version of IOS you're using.
It may also be useful to know who/what's in the other side and beyond.
Scott
Here is my configuration:
pe-coc-connect>
pe-coc-connect>
pe-coc-connect>show ver
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 25-Oct-05 17:10 by evmiller
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
pe-coc-connect uptime is 1 hour, 49 minutes
System image file is "flash:c1841-ipbase-mz.124-1c.bin"
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FTX1118Z01P
2 FastEthernet interfaces
1 Serial interface
WIC T1-DSU
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2142
pe-coc-connect>
pe-coc-connect>
pe-coc-connect#show run
Building configuration...
Current configuration : 925 bytes
version 12.4
hostname pe-coc-connect
boot-start-marker
boot-end-marker
enable secret xxx
enable password *****
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
snmp-timeout 180
ip subnet-zero
no ip routing
no ip cef
no ip dhcp use vrf connected
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
no ip route-cache
speed auto
half-duplex
no mop enabled
interface FastEthernet0/1
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
interface Serial0/0/0
ip address 10.111.248.14 255.255.255.248
encapsulation ppp
ip classless
ip route 0.0.0.0 0.0.0.0 10.111.248.9
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
password *****
login
end
pe-coc-connect#
The reason is
NO IP ROUTING
also there are no NAT statements present for 192.168.1.0/24 Network.
Muhammad
It's hard for a router to route when is told "no ip routing" :)
HX2 -- This is a jokeful remark and wish you good luck, do not hesitate to ask further questions once you have made the necessary config adjusts.
Put ip routing in configuration ,i beliave after that everthing is working, let me know if you face any problem.
-Minuj
something like:
ip route 0.0.0.0 0.0.0.0 s0/0/0
is that what is missing....
As i indicated earlier, If you look at the config you have sent, it has a statement
NO IP ROUTING
which is preventing your route to route the traffic.
0.0.0.0 0.0.0.0 is the default route for all traffic which is already present.
smothuku
Level 7
Level 7
Hi ,
go to config mode and issue the following command .
(config)#ip routing.
check whether the traffice is flowing or not after enabling ip routing.
Satish
Thanks....
That worked...
