routes redistribution between two vrf
zawawamo
Hello all,
Is it possible to redistribute the routes between two vrf's on the same router without using an external routing protocol?
thanks in advance.
2 Accepted Solutions
jsarment
To the best of my knowledge, no, you can not as they are separate instances of the routing table and neither knowns about the other. You would need to either statically route between the vrfs or use a routing protocol.
Justin
balaji.bandi
You mean with Static Routing ?
some example of IGP / BGP
https://www.cisco.com/c/en/us/support/docs/ip/ip-routing/216541-vrf-configuration-examples-on-ios-xe.html
BB
I configured the routes dynamically through EIGRP
but as I see from the guide you provided it is not possible
thanks.
jsarment
Justin
