Routing Help *Part2*
Amin Shaikh
Scenario has changed since the last post, so can someone advice if solution still Ok with additional requirement
In Our Scenario Site_A is connected to Site_B via IPSEC GRE Tunnel running OSPF as routing protocol.
Site_A host all applications for Site_B.
We already have inplace another point-2-point link between Site_A to Site_B and
have specific requirement.
POS_Server only from Site_A should send traffic on this P-2-P link to Site_B.
Any traffic initiated from Site_B to POS_Server on Site_A should be via P-2-P link.
All other traffic should pass IPSEC-Gre_Tunnel
/// Solution proposed by ediortiz :-\\\\
On the router at Site_A
access-list 101 permit ip [server_ip] [site_b subnet]
route-map server_pbr
match address 101
set ip next-hop [p-2-p link]
interface fx/x
description LAN facing interface
ip policy route-map server_pbr
On the router at Site_B
access-list 101 permit ip [site_b subnet] [server_ip]
match address 101
interface fx/x
(((Additional Scenario)))
If there is another Site IPSEC GRE Tunnel running OSPF added on _A connected to Site_C via
All traffic from Site_A to Site_C will pass using the Tunnel.
Site_A------IPSEC_GRE_Tunnel------Site_B
Site_A---------P_2_P--------------Site_B
Site_A------IPSEC_GRE_Tunnel------Site_C
Will the above configuration impact the traffic from POS_Server located on Site_A to Site_C
Edison Ortiz
It will use the routing table as the ACL being used for the PBR won't match the new site (Site_C) as a destination.
The PBR will only be used for, source POS_Server - destination Site_B subnet.
All other traffic will use the routing table.
__
Edison.
yagnesh_tel
Amin,
This depends on how you define your access list 101 on site A. If ACL 101 is just matching traffic going towards site B, you won't have any issue.
It seems from your description that that ACL 101 is defined correct way and it wont affect your traffic going towards site C.
Edison Ortiz
__
Edison.
