Routing issue - site to site
Dear all,
Based on diagram attach, how do i route the Staff PC to access the Server.
Currently the Staff can only ping up to the outside interface of ASA site A( 60.a.a.54)
What is the command to route the Staff (192.168.5.33) to Server (192.168.0.150).
18 Replies 18
i'll try tomorrow and update the result
Dear all,
I get this, can help me out guys.
kewpie-MLK-ASA# sh cry isakmp sa
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: 218.111.42.233
    Type    : user            Role    : initiator
    Rekey   : no              State   : MM_WAIT_MSG2
kewpie-MLK-ASA# debug crypto isakmp 1
kewpie-MLK-ASA# Mar 13 22:52:43 [IKEv1]: IP = 218.111.42.233, Removing peer from peer table failed, no match!
Mar 13 22:52:43 [IKEv1]: IP = 218.111.42.233, Error: Unable to remove PeerTblEntry
There are 6 Main Mode messages. Each message has a specific purpose. The status state of MM_WAIT_MSG2 could mean:
1. you are using Main Mode
2. You are waiting
3. You are waiting on Message 2 of Main mode
Message 1 is used to send your phase 1 proposals. Message 2 is sent by the remote end accepting the SA.
So the question is "Why is my ASA waiting on MSG 2?"
This could be for several reasons.
1. Maybe your packet is being dropped somewhere
2. Maybe there is a problem in the path causing the drop (High BW Utilization, bad circuit etc...)
3. The remote device believes it does not have to renogotiate or the SA is stuck for some reason
What you could try is configuring dead peer detection. This would allow the ASA to detect if the peer is gone, tear down the tunnel and allow for the new SA to be established when the peer is available.
The command below should help:
isakmp keepalive xxx
Place this on both devices then clear the isakmp SAs on both ends.
Please rate the helpful posts.
Naidu.
Hi, thanks all for the reply
I managed to get the VPN tunnel up via the ASA 5510.
Dear Lacthum Naidu,
U are correct, the 887 router block the traffic and i need to reconfigure the ACL on the 887 as below,
access-list 101 deny   esp host 60.51.196.54 host 218.111.42.234
access-list 101 deny   udp host 60.51.196.54 eq isakmp host 218.111.42.234 eq isakmp
