routing problem
sel18
Hello all,
on this lab, i can't ping to 8.8.8.8 or to the gateway (192.168.2.1).
i want to reach the cloud from any fortigate ( the address of the fortigate is a static address)
also i want to add a default router to the cloud from all the fortigate.
i am working on a local network.
please anyone could help ?
19 Replies 19
what Router is this ? get the right IOL / router image, Wipe and start from fresh, you should be ok.
glad you got Router issue and identified
BB
@balaji.bandi
the router is " cisco vIOS router "
even i try a new topology but nothing is changed
i can't ping to 8.8.8.8 and i can't open the firtigate in the website !
have you another solution please !
if the Fortinet working when you connect to Cloud - then issue with the image. google the below image and add to your lab and test.
I use PNET(same as eve)  and CML  for testing for my PoC all works great with the below IOL image.
BB
Hello
Based on your topology and the below readout then its incorrect
IF you have ip routing enabled on the rtr then a default-gateway isn't applicable, also the default static route at present will be arping for every unknown address, which is very resource intensive
Lastly I don't see any Network Translation on the rtr so unless the "cloud" is aware of those internal subnets be it via static or dynamic routing then NAT is indeed required.
For basic reachability to the cloud for the rtrs gig0/3 interface make the following changes and test again
no ip def-getaway 192.168.2.1
no ip route 0.0.0.0 0.0.0.0 gi0/3
ip routing
ip route 0.0.0.0 0.0.0.0 gi0/3 192.168.3.x < cloud next-hop ip>
Kind Regards
Paul
@paul driver
how i can get the cloud next-hop ip please ?
