Routing Protocol behavior
Tauer Drumond
Hi all....
I have two CISCO 2811 routers connected. I have two Metro-Ethernet links between them.
I've configured OSPF and when one link goes down, OSPF send all traffic through another link. That's working fine.
But my problem is, when one link is poor, not down, but loosing packtes, OSPF still continuos send traffic through this one, what
make my applications working bad.
I would like some Routing Protocol, if its possible, to observe the link condition. If its loosing packet anyway, the protocol
doesn't send traffic through it.
Is it possible?
Is there another way to do that?
Tauer
20 Replies 20
Hi Edison,
exactly, o a Metro-E, the router interface will not flap.
So... I'll look at PfR. Right?
Yes and you should feel lucky that is supported in your router.
__
Edison.
Great point...
what IOS version support this?
thanks
Tauer,
Read the link I posted earlier, it has all the information under Q&A.
Personally, I know the concept on PfR but I'm not well versed on it. The technology is very new.
__
Edison.
Ok Edison,
I have been fighting with this long time.
I thank you all by help.
Tauer
Mohamed Sobair
Level 7
Level 7
I would highly recommend (PFR) Performance routing as suggested by other colleages.
Performance routing consist of the following:
1- 2 or more boarder routers.
2- 2 or more egress interfaces.
3- Master Controller.
Performance routing takes into account the following to determine the best path in a Network.
1- Loadsharing.
2- Link
a) packet loss.
b) delay
c) delay variation (jitter)
d) utilization.
3- Cost minimization.
Unlike normal IGPs where they normally determine best paths based on Cost calculation, Performance routing takes all the above when calculation the Cost of the Path.
Performance routing is supported on some series of routers, 2800 is one of the supported Modular ISR for (PFR).
Mohamed
