Routing Protocol for L2 Extended Base-to-Base VPN
hina316
In researching configuration information, I have checked the following Cisco site.
Cisco Catalyst 8000V Edge Software Deployment in Microsoft Azure
https://www.cisco.com/c/en/us/td/docs/routers/C8000V/Azure/deploying-cisco-catalyst-8000v-on-microsoft-azure/configure-l2- extension-for-public-cloud.html
Data Migration Use Case
https://cloudnetsec.blogspot.com/2019/01/azure-and-lisp-for-workload-migration.html?m=1
I understand that I need to implement an IPSEC-VPN between locations to use LISP.
When I checked the sample configurations on the web, I found that many of them use OSPF routing between locations.
Is it possible to implement static routes without using OSPF routing?
balaji.bandi
technically that should be possible static route as default mechanism(required more manual process- if that is ok you should be ok)
until documentation mentioned any limitation.
BB
balaji.bandi
BB
Hello @balaji.bandi
Thank you for your answer.
I believe that RLOC information needs to be maintained between locations when using LISP.
Since the RLOCs use the Loopback IP, I would like to distribute the Loopback information via OSPF.
