High CPU utilization - IP Input
Sundeep Dsouza
Hello everyone,
Since the time we configured PBR, I am experiencing high CPU utilization on our core switch. I read a Cisco article on how to tackle high CPU utilization problem related to IP Input. I understand that this problem is because of Process switching which is resolved by enabling fast switching or CEF. PBR is configured on VLAN 22. Show ip interface vlan 22 displays that CEF is enabled. However check out the show interface stats and the show interface switching output below:
Vlan22
             Switch path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor  371813672  493604530   54892884 1795894790
             Route cache        126      10306          0          0
                   Total  371813798  493614836   54892884 1795894790
Vlan22
          Throttle count          0
        Drops         RP     458480         SP          0
  SPD Flushes       Fast          0        SSE          0
  SPD Aggress       Fast          0
SPD Priority     Inputs          0      Drops          0
     Protocol       Path    Pkts In   Chars In   Pkts Out  Chars Out
        Other    Process      53774    3226440          0          0
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
           IP    Process  236946062  990475192   53539326 1495552128
            Cache misses          0
                    Fast        126      10306          0          0
               Auton/SSE          0          0          0          0
          ARP    Process  134899587 3800827714    1355357   81321420
            Cache misses          0
                    Fast          0          0          0          0
               Auton/SSE          0          0          0          0
Show ip cache verbose
IP routing cache 0 entries, 0 bytes
   0 adds, 0 invalidates, 0 refcounts
Minimum invalidation interval 2 seconds, maximum interval 5 seconds,
   quiet interval 3 seconds, threshold 0 requests
Invalidation rate 0 in last second, 0 in last 3 seconds
Prefix/Length           Age       Interface       Next Hop
It seems from the above output, that the switch is doing process switching and hence the cpu hike. Despite having cef enabled, why does the switch do process switching?
Note: We do have IOS higher than 12.0.
12 Replies 12
   Which switch model and software version are you using? Please post part of PBR configuration.
Toshi
Cisco WS-C3560G-24TS - C3560-ADVIPSERVICESK9-M), Version 12.2(25)SED1.
show route-map User-vlan
route-map XYZ, permit, sequence 10
  Match clauses:
    ip address (access-lists): 189
  Set clauses:
    ip next-hop 192.168.X.X
The above route map is applied to vlan 22.
Can you provide the output for ACL 189?
If you have deny before permit, this would cause the packets to be processed in software.
Edison Ortiz
PBR is processed in hardware unless you are using an unsupported 'match|set' combination.
The only supported hardware assisted features are 'match ip address', 'set ip next-hop' and 'set ip default next-hop'.
Any other option isn't recommended as it will run in software.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
If not already enabled, you try both flow caching and policy caching.
CEF is already enabled on the interface, so I guess there is no need for enabling policy caching or flow caching right?
Show cef interface
Vlan22 is up (if_number 2070)
   Corresponding hwidb fast_if_number 2070
   Corresponding hwidb firstsw->if_number 2070
   Internet address is 192.168.22.254/24
   Secondary address 172.20.20.251/24
   Secondary address 192.168.33.2/24
   Secondary address 192.168.792/24
   ICMP redirects are always sent
   IP unicast RPF check is disabled
   Input features: NAT Outside, Policy Routing
   Output features: Post-routing NAT Outside
   Inbound access list is not set
   Outbound access list is not set
   IP policy routing is enabled
   IP policy route map is User-vlan
   BGP based policy accounting on input is disabled
   BGP based policy accounting on output is disabled
   Hardware idb is Vlan22
   Fast switching type 1, interface type 142
   IP CEF switching enabled
   IP CEF switching turbo vector
   IP prefix lookup IPv4 mtrie 8-8-8-8 optimized
   Input fast flags 0x42, Output fast flags 0x100
   ifindex 2070(2070)
   Slot 0 Slot unit 2 VC -1
   Transmit limit accumulator 0x0 (0x0)
   IP MTU 1500
Disclaimer
Posting
Yes, that's my understanding too, i.e, you shouldn't need policy caching with CEF, however I'm making a chicken soup suggestion, as it shouldn't hurt and might help.  More so true for enabling flow caching since it does, I believe, provide benefit beyond what even CEF does.
Am I reading the CEF interface information correctly that you're also doing NAT?
Nope I am not doing any NAT for this interface, atleast not on the switch. I dont know why its showing up as if we are doing NAT.
I will try enabling policy and flow caching. Any precaution to take before enabling policy and flow caching?
Regrds
isclaimer
Posting
Initially none came to mind.  But, rereading the thread I had overlooked we're working with a 3560G.  Unsure if these caching options are supported, and even if they are, might offer little to no benefit.
L3 switches really need to do their "thing" in hardware.  I've found the original 3560/3750 CPU appears slower than a 2800 ISR.  I.e., again, we want the hardware to forward packets.
So, what you really want to figure out is why the processor is being so involved.  There's likely some Cisco 3560/3750 white papers or tech notes that might help.  Off the top of my mind is whether the right SDM template is being used and/or whether TCAM resources are being exceeded.
All that I know is that the IP Input process is hogging the CPU. There is a white paper available at Cisco.com on how to tackle this issue. All it says is to enable fast caching or CEF. Since I already have CEF enabled, it leaves me no other option. Hence I need some more insight on what is causing this process to utilize the CPU.
Disclaimer
Posting
You've seen documents like?
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00807213f5.shtml
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00807ccc79.shtml#perf
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a00801e7bb9.shtml
NB: the 3750 is the "stackable" twin of the 3560
Thanks Joseph,
I went through the links you posted and found that it is not recommended to use ACLs with deny ACEs while using PBR.
Do not match ACLs with deny ACEs. Packets that match a deny ACE are           sent to the CPU, which can cause high CPU utilization.
In our case, we are using ACLs with deny ACEs and we need to have those deny statements so as to forward those traffic normally.
For you information we are using the routing template(SDM).
