Cisco 1921 / 4GLTE EHWIC - Primary Int G0/0 and Backup Cellular 0/0/0 Issues
screch101
I am looking for some help solving a problem with a Cisco 1921 and the Verizon 4G EHWIC card.  I have configured the router and it is working and was looking to add the 4G as a backup to the primary connection G0/0.  The cell interface is at Cellular0/0/0.  If I add the following command ip address negotiated to the cellular interface then the G0/0 basically stops working and I loose all internet connectivity until that startment is removed.  I don't understand why this is occurring.  Any help would be appreciated.  The only item I can think of is adding the additional something with NAT not configured correctly for that interface.  Does not seem that the cellular interface "dials" when the G0/0 interface goes down.  I have researched and have tried many different changes but nothing is fixing this issue.  The firmware is up to date on the modem and the IOS is 15.5.3.  Thanks in advance for any advice.  Below is the snippet of the config with sections removed to keep size down that does not pertain I believe.  Also included below is the cellular interface info.
version 15.5
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot system flash:c1900-universalk9-mz.SPA.155-3.M.bin
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
aaa new-model
aaa authentication login local_access local
aaa authentication login local_authen local
aaa authorization exec local_author local
aaa session-id common
ethernet lmi ce
clock timezone EST -5 0
clock summer-time EDT recurring
no ip source-route
ip dhcp excluded-address 10.7.20.1 10.7.20.120
ip dhcp pool LAN
 import all
 network 10.7.20.0 255.255.255.0
 dns-server 71.243.0.12 71.250.0.12
 default-router 10.7.20.1
no ip bootp server
ip name-server 71.243.0.12
ip name-server 71.250.0.12
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip ips config location flash:ips retries 1
ip ips notify SDEE
ip ips name IOS-IPS
ip ips signature-category
  category all
   retired true
   enabled false
  category ios_ips basic
   retired false
   enabled true
ip cef
no ipv6 cef
flow record nbar-appmon
 match ipv4 source address
 match ipv4 destination address
 match application name
 collect interface output
 collect counter bytes
 collect counter packets
 collect timestamp absolute first
 collect timestamp absolute last
flow monitor application-mon
 cache timeout active 60
 record nbar-appmon
parameter-map type inspect global
 max-incomplete low 18000
 max-incomplete high 20000
 nbar-classify
chat-script lte "" "AT3CALL" TIMEOUT 60 "OK"
password encryption aes
cts logging verbose
crypto pki trustpoint TP-self-signed-2901148831
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2901148831
 revocation-check none
 rsakeypair TP-self-signed-2901148831
license udi pid CISCO1921/K9 sn XXXXXXXXX
license boot module c1900 technology-package datak9
object-group network local_lan_subnets
username XXXXX privilege 15 secret 5
username XXXXX privilege 12 secret 5
redundancy
controller Cellular 0/0
 lte modem link-recovery rssi onset-threshold -110
 lte modem link-recovery monitor-timer 20
 lte modem link-recovery wait-timer 10
 lte modem link-recovery debounce-count 6
no cdp run
ip tcp synwait-time 10
policy-map type inspect LAN-WAN-POLICY
policy-map type inspect WAN-LAN-POLICY
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
zone-pair security LAN-WAN source LAN destination WAN
 service-policy type inspect LAN-WAN-POLICY
zone-pair security WAN-LAN source WAN destination LAN
 service-policy type inspect WAN-LAN-POLICY
interface Embedded-Service-Engine0/0
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip virtual-reassembly in
 shutdown
interface GigabitEthernet0/0
 description PrimaryWANDesc_FiOS
 ip address dhcp
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip flow ingress
 ip nat outside
 ip ips IOS-IPS in
 zone-member security WAN
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 description Home LAN
 ip address 10.7.20.1 255.255.255.0
 no ip redirects
 no ip proxy-arp
 ip nbar protocol-discovery
 ip flow monitor application-mon input
 ip flow ingress
 ip flow egress
 ip nat inside
 zone-member security LAN
 load-interval 30
 duplex auto
 speed auto
 no mop enabled
interface Cellular0/0/0
 description BackupWANDesc_LTE
 no ip address
 ip nat outside
 encapsulation slip
 dialer in-band
 dialer string lte
 async mode interactive
ip forward-protocol nd
ip http server
ip http upload enable path flash:
ip http upload overwrite
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
no ip ftp passive
ip nat inside source list nat-list interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 track 1
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0 253
ip route 8.8.8.8 255.255.255.255 GigabitEthernet0/0
logging trap debugging
dialer-list 1 protocol ip permit
control-plane
banner incoming ^CCisco 1921 K9/Security^C
banner login ^C
  *** UNAUTHORIZED ACCESS TO THIS DEVICE IS PROHIBITED ***
             For Authorized Offical Use Only
        You must have explicit permission to access
    or configure this device.  All activities performed
      on this device are logged, and violations of
           this policy may be reported to law
                 enforcement authorities.
         There is no right to privacy on this device. ^C
line con 0
 login authentication local_access
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 0/0/0
 script dialer lte
 modem InOut
 no exec
line vty 0 4
 access-class 23 in
 privilege level 15
 transport input telnet ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 131.107.13.100 prefer source GigabitEthernet0/0
end
Cellular Info Below:
Cellular 0/0/0 Interface Info
show cellular 0/0/0 network
Current System Time = Mon Aug 24 2:57:48 2015
Current Service Status = Normal
Current Service = Packet switched
Current Roaming Status = Home
Network Selection Mode = Automatic
Network = Verizon Wireless
Mobile Country Code (MCC) = 311
Mobile Network Code (MNC) = 480
Packet switch domain(PS) state = Attached
Registration state(EMM) = Registered
EMM Sub State = Normal Service
Tracking Area Code (TAC) = 14595
Cell ID = 14598913
show cellular 0/0/0 radio
Radio power mode = ON
LTE Rx Channel Number =  5230
LTE Tx Channel Number =  23230
LTE Band =  13
LTE Bandwidth = 10 MHz
Current RSSI = -83 dBm
Current RSRP = -116 dBm
Current RSRQ = -17 dB
Current SNR = -2.0  dB
Radio Access Technology(RAT) Preference = AUTO
Radio Access Technology(RAT) Selected = LTE
show cellular 0/0/0 profile
Profile password Encryption level: 7
Profile 1 = INACTIVE **
PDP Type = IPv4
Access Point Name (APN) = vzwinternet
Authentication = None
Profile 2 = INACTIVE
PDP Type = IPv4v6
Access Point Name (APN) = vzwadmin
Profile 3 = INACTIVE*
PDP Type = IPv4
Profile 4 = INACTIVE
PDP Type = IPv4v6
Access Point Name (APN) = vzwapp
Profile 5 = INACTIVE
PDP Type = IPv4
  * - Default profile
 ** - LTE attach profile
show cellular 0/0/0 security
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of CHV1 Retries remaining = 3
show cellular 0/0/0 all
Hardware Information
Modem Firmware Version = SWI9600M_03.05.10.06ap
Modem Firmware built = 2012/11/12 15:07:45
Hardware Version = 10
Device Model ID: MC7750
Package Identifier ID: MC7750_03.05.10.06_00_vzw_033.011_000
International Mobile Subscriber Identity (IMSI) = 311480039061020
International Mobile Equipment Identity (IMEI) = 990000820070961
Integrated Circuit Card ID (ICCID) = 89148000000384557279
Mobile Subscriber Integrated Services
Digital Network-Number (MSISDN) = 7745030447
Current Modem Temperature = 34 deg C
PRI SKU ID = 9900853, PRI version = 00.05, Carrier = 5
Profile Information
PDP Type = IPv6
Access Point Name (APN) = vzwims
PDP Type = IPv4v6
PDP Type = IPv4
PDP Type = IPv4v6
PDP Type = IPv4
  * - Default profile
Data Connection Information
Profile 1, Packet Session Status = INACTIVE
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Network Information
Current System Time = Mon Aug 24 3:1:8 2015
Cell ID = 14598913
Radio Information
LTE Band =  13
Current RSRP = -117 dBm
Current SNR = -3.3  dB
Modem Security Information
SIM Status = OK
GPS Information
GPS Info
GPS Feature: enabled
GPS Port Selected: Dedicated GPS port
GPS State: GPS disabled
SMS Information
Incoming Message Information
SMS stored in modem = 23
SMS archived since booting up = 0
Total SMS deleted since booting up = 0
Storage records allocated = 25
Storage records used = 23
Number of callbacks triggered by SMS = 0
Number of successful archive since booting up = 0
Number of failed archive since booting up = 0
Outgoing Message Information
Total SMS sent successfully = 0
Total SMS send failure = 0
Number of outgoing SMS pending = 0
Last Outgoing SMS Status = SUCCESS
Copy-to-SIM Status =     0x0
Send-to-Network Status = 0x0
Report-Outgoing-Message-Number:
  Reference Number =     0
  Result Code =          0x0
  Diag Code =            0x0 0x0 0x0 0x0 0x0
SMS Archive URL =
Error Information
This command is not supported on this platform.
Modem Crashdump Information
Modem crashdump logging: off
30 Replies 30
Chris Russo
I have played a lot with these interfaces and if the interface drops when getting your IP it could be a NAT issue. The reason the interface drops is because of something called an IP source violation. If the provider sees traffic coming in through the cell interface that isn't properly NATed, the connection will drop. What you can do is create an access-list denying all inside traffic from traversing the cell interface. Btw, where is your NAT ACL for your "nat-list"? Also, I noticed that none of your cellular profiles are active. Try enabling  the interface again using an ACL to block RFC 1918 IPs from going out of the interface and let me know what happens. I've had to troubleshoot these a lot... Here is an example of our config.
 description To Verizon Cellular Network
 no ip unreachables
 ip nat outside
 encapsulation slip
 load-interval 30
 shutdown
 dialer in-band
 dialer idle-timeout 0
 dialer enable-timeout 6
 dialer string ltescript
 dialer watch-group 1
chat-script ltescript "" "AT!CALL1" TIMEOUT 20 "OK"
chat-script lte "" "AT!CALL" TIMEOUT 60 "OK"
dialer watch-list 1 ip 5.6.7.8 0.0.0.0
dialer watch-list 1 delay route-check initial 60
dialer watch-list 1 delay connect 1
ip nat inside source route-map NAT-CELL interface Cellular0/0/0 overload
P.S. I haven't included the route-map or ACLs for the NAT config
Thanks for responding I appreciate the insight.  I was going to add the following statement to my config thinking this might be part of the problem because it is not included.  Your info kind of validates my thoughts on the NAT issue.
ip nat inside source list nat-list interface Cellular0/0/0 overload
I have not manged to get any of the profiles to show active that is another item that I cannot figure out so far.  This has been frustrating.  The interface is a backup ONLY to G0/0.  Would the profile become active once the G0/0 interface goes down?
Thanks for help in this situation.  I appreciate it.
-Fred
Yes you need to make sure you NAT out of the cellular interface as well. AT least one of the profiles should show active once your connection to the cellular network is established regardless if G0/0 is up or down.
So adding that ip nat statement is for sure.  As far as the dial portion of the config do I need to add that?  I don't have any of the 3 below statements in my config.
I do have the following included.
chat-script lte "" "AT1CALL" TIMEOUT 60 "OK"   - Changed this to profile 1 instead of 3
line 0/0/0
 script dialer lte
 modem InOut
 no exec
It's my understanding that the dialer watch list will basically keep the cellular interface up at all times, instead of just connecting when establishing a "call". Adding those 3 dialer watch-list commands definitely won't hurt.
Do I really need it up all the time if it is a backup just in case the other interface goes down?
We have ours up all the time and we are using it as a backup connection as well. We just have the cell connection as a default floating static route with a higher AD than our primary interface. The choice is up to you.
Thanks for help on this.  Do I have to create a new ACL for NAT for that interface.  I have not done many still learning in and outs of CLI.  What is you recommendation on setting this up.  My current ACL's are below.
ip access-list extended diskstation_acl
 permit object-group diskstation_svc object-group diskstation_src_net object-group diskstation_dst_net
ip access-list extended energy_detective_acl
 permit object-group energy_detective_svc object-group energy_detective_src_net object-group energy_detective_dst_net
ip access-list extended lan_acl
 permit object-group lan_svc object-group lan_src_net object-group lan_dst_net
ip access-list extended mobile_net_extender_acl
 permit object-group mobile_net_extender_svc object-group mobile_net_extender_src_net object-group mobile_net_extender_dst_net
ip access-list extended nat-list
 permit ip object-group local_lan_subnets any
 deny   ip any any
ip access-list extended rdp_server_acl
 permit object-group rdp_server_svc object-group rdp_server_src_net object-group rdp_server_dst_net
What would the command be to set this correctly.  I am guessing after the ACL is set then I should add the below:
ip nat inside source list nat-cell interface Cellular0/0/0 overload
Once again thanks for your help on this.  Great expertise on this.  Seems like you have had a lot of experience with this.
-Fred
Hello Chris,
Well I had a chance to work on this and here is what happens...you can correct me when and wherever I made a mistake,
I added the following ACL..I think I did it correctly.
Extended IP access list nat-cell
    10 permit ip object-group local_lan_subnets any
    20 deny ip any any
This below is the current one:
Extended IP access list nat-list
    20 deny ip any any
Added to the Cellular0/0/0: ip address negotiated
Then added the following command:
Once that was added I lose all internet connectivity until removed?
What am I doing wrong.  I did not get profile to go active.  I also did not try adding dialer statements but that will be next.
Any suggestions?
Thanks.
Can you be more specific when you say "loose all internet connectivity"? Does this mean that your primary connection drops when you add the ip address negotiated command? I would manually shut down your primary connection and attempt troubleshooting the cellular interface until you establish connectivity through the cell. Just to be safe I would also at an ACL that denies all private IP address space from exiting the cell interface in order to avoid an IP source violation.
I try to ping anything inside IOS and it fails and hence it looks like no connectivity to "outside".
I'm not sure what you mean by that. It may be time to open up a TAC case.
Basically it seems like the G0/0 interface stops passing any traffic.I will do that as it seems something weird is going on.  Thanks for all the help.
Yeah it shouldn't do that since you have a weighed route pointing to the cell interface. The cell interface coming up should not cause G0/0 to not pass traffic.
