SDM Not working
wasiimcisco
I have cisco rouer 3825 but unable to access via SDM. Please see the configuration in attachement. i tried with https, http and via SDM loaded. getting page cant be displayed.
Please help me out
russell.turner
Can you access the device through telnet. One thing I do see is under vty there is not a "login local" entry. Here is a link for SDM
http://www.cisco.com/univercd/cc/td/doc/product/software/sdm/sdmqsg/sdmq21.htm#wp51612
jamesl0112
In addition to login local, you will also need to specify privilege level 15 when configuring the VTY lines.
anitachoi3
Try following:
1. connect one PC to 192.168.32.0 segment. the IP address of PC is 192.168.32.10/24
2. launch IE
3. key in: https://192.168.32.2
You should get the login promopt.
BTW, pls check the 802.1q setting.
rdgs
ellendrew
Make sure java is installed on your PC and ip http server is also enabled on your router.
