Searching IOS for Cisco 2821
ashish.sehgal1
Cisco 2821
      Interfaces
Software Version System imageNVRAMRAMATA CompactFlashGigSerialE1
C2800NM-SPSERVICESK9-M12.4(9)T6c2800nm-spservicesk9-mz.124-9.T6.bin239K bytes514048K/10240K bytes126000K bytes222
installing below HWIC card in Cisco 2821. I understand I need to upgrade the IOS for the reason. Kindly suggest, how to search.
Part NumberDescription
HWIC-2FE=Two 10/100 routed port HWIC
1. Do I really need to upgrade the IOS ? if yes
2. How to search new compatible IOS for the above router ?
2 Accepted Solutions
AllertGen
Level 3
Level 3
Hello, .
All information of this HWIC (what IOS you need, how much you can install, etc) you can find here: http://www.cisco.com/c/en/us/products/collateral/routers/2800-series-integrated-services-routers-isr/product_data_sheet0900aecd80581fe6.html
IOS you can download here: https://software.cisco.com/download/navigator.html?mdfid=268437899 (if you have a license).
Best Regards.
vaib7av.shirkul
Hi Ashish,
You must have to upgrade the IOS, because minimum software version support for this card is 12.4(20)T - IP BASE.
Pl refer Table 1A in below document.
- HTH
AllertGen
Level 3
Level 3
Hello, .
Best Regards.
Amazing brothers, thanks for immediate response. I salute you.
vaib7av.shirkul
Hi Ashish,
- HTH
