Serial is reset ,protocol is down
ergingenc
Does anybody have an idea about the ;
Serial3/0 is reset ,protocol is down
What can be the cause of this problem?
ERGIN GENC
CCNP
kamal-learn
Level 4
Level 4
it seems you have a layer 2 or 1 problem , are you using the correct encapsulation that your peer use ?
in the case of a frane-relay are using the adequate lmi type (cisco ietf q933a )?
are you using no keepalive ? after three atempts it put the line down if there is no keepalives.
do a (clear interface counters ) and watch it again .\
do rate if it does
"serial is RESET ,protocol is down"
I want to learn the cause of the RESET word.Why it doesnt show "serial is down"?
