Setting up route for 2 networks with the same ip address
gal.avichid
I have 2 environment with in separate rooms with the same subnet 10.10.10.0/24
each environment connected to a
env1-switch, this sw connected to cisco asa1(192.168.14.2) connected to myciscoasa(192.168.14.1)
env-2switch, this sw connected to cisco asa1(192.168.16.2) connected to myciscoasa(192.168.16.1)
If i add static route, only the route with the higher metric is working. how can i set both routes to operate and not leak to each other?
Thanks !
17 Replies 17
Can you draw topolgy
MHM
Hope you can understand what i meant
let me know if need more info
eventually ill need to allow communication between the 10.10.10.0/24 network to the other network in the squared color.
but not allow communication between computers in the green square to the red square and vice versa
Hello @gal.avichid
You cannot have the same IP subnet attached to different L3 equipment without employing advanced techniques like VRF or NAT...so more complex routing configurations.
Each subnet should be unique within a given L3 domain. When same subnets are attached to different L3 equipment, it can lead to issues with routing and confusion about the next hop for specific IP addresses...
Best regards
Can you give some more info about the principal with the NAT?
@gal.avichid
When dealing with overlapping subnets across two environments connected to separate Cisco ASA devices, NAT is crucial for facilitating communication. Implement Dynamic PAT on the common network interface of the Cisco ASA facing both environments, mapping multiple private IP addresses to a single public IP address (e.g., 192.168.14.1) using different port numbers. This configuration ensures unique identification of source IP addresses. Verify that traffic from both environments can reach the common network using the translated public IP address. Additionally, implement firewall rules to control traffic flow and consider NAT exemption for specific communications.
Best regards
MHM
One min
can you check if ASA support VRF ?
if Yes you can use same subnet in separate VRF and hence achieve both your requirement
Exactly @MHM Cisco World
It is multi-context on the ASA no ?
Best regards
I will check VRF in ASA
it as you mention before solve by VRF or NAT one NAT 10.10.10.0/24 to other subnet and then using route in MyCiscoASA toward the Mapped IP not real IP and hence we get one route for 10.10.10.0/24 and other route for Mapped IP
and for isolation he can use ACL to drop any traffic between these interface.
BUT I prefer VRF is ASA support it
thanks
MHM
Agree with you @MHM Cisco World !
Best regards
I can't find VRF, my ASA 5506 is without any special license, so I can't believe I have this option.
I have tried set the NAT, but I guess i forgot something:
ciscoasa(config)# object network obj-10.10.10.0
ciscoasa(config-network-object)# subnet 10.10.10.0 255.255.255.0
ciscoasa(config)# object network obj-mapped-ip-range
ciscoasa(config-network-object)# range 192.168.171.0 255.255.255.0
ciscoasa(config)# nat (cc-171,inside-171) source dynamic obj-10.10.10.0 obj-mapped-ip-range
ciscoasa(config)# route cc-171 192.168.171.0 255.255.255.0 192.168.16.2
ciscoasa(config)# nat (cc-171,inside-171) source dynamic obj-mapped-ip-range <- we add NAT under real object not under mapped object
ciscoasa(config)# route cc-171 192.168.171.0 255.255.255.0 192.168.16.2 <- I dont get why you add this route in ciscoasa it must be in MyciscoASA
For VRF yes it true that ASA not support vrf only ftd.
MHM
what is the difference between mapped object and real object?
is the NAT rule need to be on the ciscoasa or MYCISCOASA?
real IP object <<- that include real IP
mapped IP object <<- that include mapped IP
