Setting up route for 2 networks with the same ip address
gal.avichid
I have 2 environment with in separate rooms with the same subnet 10.10.10.0/24
each environment connected to a
env1-switch, this sw connected to cisco asa1(192.168.14.2) connected to myciscoasa(192.168.14.1)
env-2switch, this sw connected to cisco asa1(192.168.16.2) connected to myciscoasa(192.168.16.1)
If i add static route, only the route with the higher metric is working. how can i set both routes to operate and not leak to each other?
Thanks !
17 Replies 17
post the full running configs of the firewall, as well as the two routers (192.168.14.1 and 192.168.16.1)...
Hello
Curious are those IE switches that have the duplicate 10.10.10.0/24 subnet running behind them? if so then you should be able to use L2NAT on those IE switches to allow communication between the 10.10.10.x/24 subnet
Kind Regards
Paul
unfortunately its a HPE switches
