sh access-list output 'check' ?
jvhaysx
I can't find anything on CCO or Google to explain the 'check==378' in the output below.
router#sh access-list 1
Standard IP access list 1
permit 10.25.0.0, wildcard bits 0.0.0.255 check=378
This is just a snippet. Other ACLs on the same router do not have the 'check' field - just this one, which is an access-class ACL on the vty. See config below:
access-list 1 permit 10.25.0.0 0.0.0.255
line vty 0 4
access-class 1 in
Also, Cisco Output Interpreter just chokes on this output. The router is a 1721 running 12.2(8)T5.
Please advise. - Jonathan
royalblues
Level 10
Level 10
Jonathan,
The access-list in question must be having a log keyword at the end.
The check =378 actaully means that the access-list has been referred to 378 times.
You can use the clear access-list counters command (check =0)and then try the telnet access from the subnet. Then issue the sh access-list command. the check counter would have incremented.
HTH, rate if it does
Narayan
