Simple NAT Network
feroz syed
Level 3
Level 3
i try to access web server(8.8.8.8) but it didn't work, here is my cmds :-
interface FastEthernet0/0
ip address 88.84.121.121 255.255.255.0
ip nat outside
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
interface Serial0/1/0
ip address 192.168.50.1 255.255.255.0
clock rate 64000
interface Serial0/1/1
no ip address
shutdown
interface Vlan1
no ip address
shutdown
ip nat inside source list NAT interface FastEthernet0/0 overload
ip classless
ip access-list standard NAT
permit 192.168.1.0 0.0.0.255
then this won't work because routing is done first before NAT and you don't have a route for 8.8.8.8 on the router and the server has got no route for 88.84.121.0/24 as it has no connected interface in that subnet.
change your server address to 88.84.121.2/24 and you'll be natting your inside subnet.
Alain
cadet alain
your server with 8.8.8.8 must have an ip address in the 88.84.121.0/24 network. How did you configure your server?
Is the default gateway of the PC correctly configured(192.168.1.1) and in same subnet as the ip of the machines ?
Alain
hi, web server just have a single ip address without any gateway, and yes all pc has default gw of 1.1. i can able to ping 88.84.121.121 ip.
Alain
