SIP inspect
ajay chauhan
Level 7
Level 7
Hi ,
what are the command required to enable SIP inspect on cisco 7200 router .
Pravin Phadte
Level 5
Level 5
ou have to list them before tcp or udp keywords, otherwise their control streams will not be inspected and there will be no provision for data sessions.
ip inspect name Internet
ip inspect name Internet h.323 router-traffic
ip inspect name Internet sip router-traffic
interface FastEthernet0/0
ip inspect Internet out
Below is the link for more reference.
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_i2.html
Hope this helps,
Pravin
Hi Pravin,
can u pls explain me little more where to use tcp and udp keywords ?
and in which direction i need to apply inpect rule do i need to apply on both interfaces In and Out?
Actually I believe that no inspect command is needed for SIP.
Current IOS applye "NAT SIP ALG" automatically without configuring anything.
