SIP QOS on CIsco 887VA Help
DOUGLAS DRURY
Hi All.
I’m looking for some help with SIP/VOIP prioritization on my Cisco 887va.  We have a remotely hosted SIP phone system.  The problem is when we are working on PC’s for clients and they start to download updates for Windows 10 we are getting choppy audio on calls.  I’m trying to fix this with some QOS/priority towards SIP traffic.  However, in my testing and development I need a bit of help.
Below is my configuration that I’m adapted from examples.  We are on an FTTC/VDSL line 70Mb download and 20Mb Upload speeds.
ip access-list extended VOIP
permit tcp any any range 6000 6049
permit tcp any any eq 5060
class-map match-any VoIP
match access-group name VOIP
policy-map VOIPQOS
class VoIP
priority percent 50
set dscp ef
class class-default
fair-queue
When I try to apply this to the dialer interface I get the below error
RT (config-if)#service-policy output VOIPQOS
Flow Fair Queueing feature is not supported in default class of parent level policy of
11 Replies 11
I think it has to do with the IOS version you are running...which one do you have ?
Try and apply the service policy to the physical (ATM) interface, that should get rid of the error message....
Thanks for the reply.
I'm using IOS: System image file is "flash:c880data-universalk9-mz.153-3.M9.bin"
When I tried to apply the command to the interface I go the below.  I'm on a VDSL line so I use Ethernet0.101
RT(config)#inter ethernet 0.101
RT(config-subif)#service-policy output VOIPQOS
CBWFQ : Not supported on subinterfaces
RT(config-subif)#exit
RT(config-if)#
RT(config-if)#service-policy output VOIPQOS
Service_policy with queueing features on this interface is not allowed
if dialer based queuing policy is already installed.
RT(config-if)#
have you removed the service policy from the dialer interface before applying it to the physical interface ?
I couldn't apply it to the dialer interface anyway because the router rejected the command with the error: Flow Fair Queueing feature is not supported in default class of parent level policy of.
try to configure a child policy as below, then apply the parent policy to the interface:
policy-map VOIPQOS_CHILD
 class VoIP
 priority percent 50
 set dscp ef
class class-default
 fair-queue
policy-map VOIPQOS_PARENT
 class class-default
 service-policy VOIPQOS_CHILD
I tried your suggestion and got the below for each of the interfaces.  It hasn't applied to any of the interfaces
RT(config-if)#service-policy output VOIPQOS_PARENT
Cannot attach queuing-based child policy to a non-queuing based class
RTconfig-if)#
RT(config-subif)#service-policy output VOIPQOS_PARENT
RT(config)#
RT(config)#interface ether 0
RT(config)#
post the full current configuration of your router if possible...
the problem might be that you have to configure something under the default class in the parent policy. Try and add the below (in bold):
class VoIP
priority percent 50
set dscp ef
class class-default
fair-queue
class class-default
shape average 20000000
Thanks for your help so far.
I tried to add shape average 20000000 in the parent policy but the router rejected it with % Invalid input detected at '^' marker.  The marker was at shape
Below is my configuration.
RT#sh run br
Building configuration...
Current configuration : 5419 bytes
! Last configuration change at 08:18:00 UTC Fri Nov 10 2017 by doug
version 15.3
no service pad
hostname RT
boot-start-marker
boot system flash:c880data-universalk9-mz.153-3.M9.bin
boot system flash:c880data-universalk9-mz.153-3.M.bin
boot-end-marker
enable secret 4 sii94NGY12oyst/3n4bnmySHfE/PcvkoNt83rjGoB8I
aaa new-model
aaa authentication login VPNUSERSAUTH local
aaa authorization network VPNUSERS local
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-1949736083
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1949736083
revocation-check none
rsakeypair TP-self-signed-1949736083
crypto pki certificate chain TP-self-signed-1949736083
certificate self-signed 01
ip dhcp excluded-address 192.168.20.20 192.168.20.50
ip dhcp excluded-address 192.168.1.1 192.168.1.20
ip dhcp excluded-address 192.168.1.200 192.168.1.254
ip domain name REMOVED.local
ip name-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO887VA-SEC-K9 sn FCZ181070DN
username REMOVED privilege 15 secret 4 REMOVED
controller VDSL 0
firmware filename flash:VA_A_39m_B_38h3_24h.bin
class VoIP
priority percent 50
set dscp ef
class class-default
fair-queue
class class-default
crypto isakmp policy 7
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key REMOVED address REMOVED no-xauth
crypto isakmp client configuration group VPNUSERS
key REMOVED
dns 192.168.1.201
domain REMOVED.local
pool VPN-POOL
acl VPNSPLIT
crypto ipsec transform-set REMOVED esp-3des esp-md5-hmac
mode tunnel
crypto dynamic-map VPNDYNMAP 1
set transform-set REMOVED
reverse-route
crypto map MAP-OUTSIDE client authentication list VPNUSERSAUTH
crypto map MAP-OUTSIDE isakmp authorization list VPNUSERS
crypto map MAP-OUTSIDE client configuration address respond
crypto map MAP-OUTSIDE 10 ipsec-isakmp
set peer REMOVED
match address S2S
crypto map MAP-OUTSIDE 65000 ipsec-isakmp dynamic VPNDYNMAP
interface Ethernet0
no ip address
interface Ethernet0.101
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
switchport mode trunk
no ip address
interface FastEthernet1
switchport access vlan 20
no ip address
interface FastEthernet2
switchport access vlan 90
no ip address
interface FastEthernet3
no ip address
interface Vlan1
ip nat inside
ip virtual-reassembly in
interface Vlan15
ip address 192.168.15.3 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip nat inside
interface Vlan90
ip address 10.1.1.1 255.255.255.0
ip nat inside
interface Dialer1
description BT VDSL
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
ppp authentication pap chap ms-chap callin
ppp chap hostname REMOVED
ppp chap password 0 REMOVED
ppp ipcp address accept
no cdp enable
router eigrp 10
network 192.168.1.0
network 192.168.20.0
ip local pool VPN-POOL 10.1.74.5 10.1.74.250
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source list NAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.15.0 255.255.255.0 Vlan1
ip route 192.168.30.0 255.255.255.0 192.168.20.203
ip access-list extended NAT
deny ip 192.168.15.0 0.0.0.255 192.168.40.0 0.0.0.255
deny ip 192.168.1.0 0.0.0.255 192.168.40.0 0.0.0.255
deny ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
deny ip 192.168.1.0 0.0.0.255 10.1.74.0 0.0.0.255
deny ip 192.168.20.0 0.0.0.255 10.1.74.0 0.0.0.255
deny ip 10.1.1.0 0.0.0.255 10.1.74.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 any
permit ip 192.168.20.0 0.0.0.255 any
permit ip 10.1.1.0 0.0.0.255 any
ip access-list extended S2S
permit ip 192.168.15.0 0.0.0.255 192.168.40.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
ip access-list extended VPNSPLIT
permit ip 192.168.1.0 0.0.0.255 10.1.74.0 0.0.0.255
permit ip 192.168.20.0 0.0.0.255 10.1.74.0 0.0.0.255
permit ip 192.168.15.0 0.0.0.255 10.1.74.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
transport output telnet ssh
end
RT#
try and disable NBAR protocol discovery on the dialer interface:
--> no ip nbar protocol-discovery
What are your options in the default class ('shape' is giving an error, what else is there) ?
Joseph W. Doherty
Are you also doing general Internet access using the same link?
If so, to effectively manage VoIP traffic, you have to preclude general Internet access on the same link. This because, you can not generally well manage ingress bandwidth, so Internet traffic will generally disrupt VoIP traffic regardless of what you do.
