slow performance-cisco 2621
mahbobsun
in our branch office. we are using cisco 2621 as edge router connected to 10M uplink leased line. and for users using 3560.
users always complaing about slow speed while there is no error anywher in the interface.except some drops in input queue.
18 Replies 18
A Abdul
It could be circuit over utilization. The input queue that is dropping is it the default queue or specific QoS queue?
Please provide output of sh policy-map int xyz & sh int.
Also ping to the provider ip and see the transit times, trace to HQ and see if there is hop that has high RTT.
no over utilization. no policy map is being used.
FastEthernet0/0 is up, line protocol is up
Description: connection to ISP
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 02:04:11
  Queueing strategy: fifo
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
  5 minute input rate 553000 bits/sec, 162 packets/sec
  5 minute output rate 534000 bits/sec, 161 packets/sec
     654494 packets input, 548495024 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     527980 packets output, 140498965 bytes, 0 underruns
     0 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is up
  Description: connection to switch
  Last clearing of "show interface" counters 02:05:42
  Output queue 0/40, 0 drops; input queue 0/75, 8 drops
  5 minute input rate 416000 bits/sec, 123 packets/sec
  5 minute output rate 420000 bits/sec, 121 packets/sec
     492351 packets input, 140222392 bytes
     Received 3173 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     613104 packets output, 546214184 bytes, 0 underruns
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
10 Mbps WAN link?  A 2621 is only rated at 25 Kpps; a little "light" for supporting 10 Mbps.
What's you CPU usage history look like?
Is you 10 Mbps uplink Ethernet?  Full 10 Mbps both directions?  PPPoE?  (If Ethernet, why not connect to the 3560?)
it is a 10M ethernet. it has been set up years back.the same setup is being used in most of the sites with 100M uplink and we have no issues!
for both devices the IOS version is very old too. but not sure if it could cause the issue:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(6a), RELEASE SOFTWARE (fc1)
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(50)SE1, RELEASE SOFTWARE (fc2)
     611111     11111          11111     11111     11111     11
100
90
80
70
60
50
40
30
20
10  *
    0....5....1....1....2....2....3....3....4....4....5....5....
              0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
       1    11 5  321 1     21257222211   32 31  21112 2422 1 1
     1596899007946401709346619930276660665523228902243960539695
100
90
80
70                             *
60            *                *
50            *               **
40            *               **         *             *
30            *  *           *** ***     *  *         ***
20    *       *  **        ****#*****    ** *   *   * *#** * *
10   *#*******# *#*****  **#########*****## #***##*##*###*****
              0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
     4657567644454455554565565666765555955445546655456555655554555354554454
     4744805485374276049017623010614479021348824558575861526267012908152482
100
90                                    *
80        *                     *     *
70   * *  *                     *     *        *    *   *
60   * *****   *  **    **** *****  ***    ** **** **** * * *        *  *
50   ********* *  ***********************  ** ******************* ****  *
40  **********************************************************************
30  **********************************************************************
20  **********************************************************************
10  ########**************##########***************####*###***************
    0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
              0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
JohnTylerPearce
Level 7
Level 7
Robab,
Can you post the results from 'show run int fa0/0' and 'show run int fa0/1' ?
Also can you post the results from 'show int fa0/0 switchport and show int fa0/1 switchport' ?
interface FastEthernet0/0
ip address XX
ip access-group INBOUND in
ip nat outside
ip route-cache same-interface
ip route-cache policy
no ip mroute-cache
speed 100
full-duplex
no cdp enable
end
interface FastEthernet0/1
description connection to switch
ip address YY
ip accounting mac-address input
ip nat inside
no ip mroute-cache
duplex auto
speed auto
end
Robab,
Well part of the poblem is obviously the CPU getting hit hard.
Can you provide the output of 'show processes cpu sorted"
Also, is there a reason you are using Fast Cache (ie ip route-cahce) and not CEF on these interfaces?
Also, can you provide the output of 'show logging'
I added it to see if it makes it better! but it didnt!!
sorted command is not working
CPU utilization for five seconds: 22%/19%; one minute: 7%; five minutes: 5%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1        2484    399699          6  0.00%  0.00%  0.00%   0 Load Meter
   2        2204     18341        120  0.00%  0.00%  0.00%   0 TACACS+
   3      920588    237115       3882  0.00%  0.03%  0.01%   0 Check heaps
   4           4         1       4000  0.00%  0.00%  0.00%   0 Chunk Manager
   5        1960       924       2121  0.00%  0.00%  0.00%   0 Pool Manager
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
   7           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
   8        2240    399493          5  0.00%  0.00%  0.00%   0 ALARM_TRIGGER_SC
   9         416     66615          6  0.00%  0.00%  0.00%   0 Environmental mo
  10       43392    130553        332  0.00%  0.00%  0.00%   0 ARP Input
  11           4         2       2000  0.00%  0.00%  0.00%   0 DDR Timers
  12           4         2       2000  0.00%  0.00%  0.00%   0 Dialer event
  13           4         3       1333  0.00%  0.00%  0.00%   0 Entity MIB API
  14           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  15           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  16       21360    353676         60  0.00%  0.00%  0.00%   0 Net Background
  17           4        37        108  0.00%  0.00%  0.00%   0 Logger
  18       16900   1997637          8  0.00%  0.00%  0.00%   0 TTY Background
  19       16100   1997704          8  0.00%  0.00%  0.00%   0 Per-Second Jobs
  20           0         2          0  0.00%  0.00%  0.00%   0 Hawkeye Backgrou
  21        4868       840       5795  2.53%  0.30%  0.08%  66 Virtual Exec
  22           0         1          0  0.00%  0.00%  0.00%   0 HDV background
  23           0         2          0  0.00%  0.00%  0.00%   0 VNM DSPRM MAIN
  24       64920    448280        144  0.00%  0.00%  0.00%   0 Net Input
  25        2060    399700          5  0.00%  0.00%  0.00%   0 Compute load avg
  26      710392     33871      20973  0.00%  0.02%  0.00%   0 Per-minute Jobs
  27           0         1          0  0.00%  0.00%  0.00%   0 CES Line Conditi
  28           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  29    18167740  15852687       1146  0.24%  0.98%  0.63%   0 IP Input
  30       39580    233180        169  0.00%  0.00%  0.00%   0 CDP Protocol
  31           0         1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
  32           0         2          0  0.00%  0.00%  0.00%   0 PASVC create VA
  33           4         1       4000  0.00%  0.00%  0.00%   0 Asy FS Helper
  34           0         1          0  0.00%  0.00%  0.00%   0 PPP IP Add Route
  35       31316     36014        869  0.00%  0.00%  0.00%   0 IP Background
  36       14764     33313        443  0.00%  0.00%  0.00%   0 Adj Manager
  37         448      5795         77  0.00%  0.00%  0.00%   0 TCP Timer
  38        1816      1279       1419  0.00%  0.00%  0.00%   0 TCP Protocols
  39           0         1          0  0.00%  0.00%  0.00%   0 Probe Input
  40           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
  41           0         1          0  0.00%  0.00%  0.00%   0 HTTP Timer
  42           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
  43        2496      1933       1291  0.00%  0.00%  0.00%   0 DHCPD Receive
  44       60496     33300       1816  0.00%  0.00%  0.00%   0 IP Cache Ager
  45           0         1          0  0.00%  0.00%  0.00%   0 COPS
  46           0         1          0  0.00%  0.00%  0.00%   0 PAD InCall
  47           0         2          0  0.00%  0.00%  0.00%   0 X.25 Background
  48       13188   1997679          6  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
  49           0         1          0  0.00%  0.00%  0.00%   0 bsm_timers
  50        4852   1997644          2  0.00%  0.00%  0.00%   0 bsm_xmt_proc
  51           0         1          0  0.00%  0.00%  0.00%   0 SNMP Timers
  52           0         1          0  0.00%  0.00%  0.00%   0 CES Client SVC R
  53        3168    217138         14  0.00%  0.00%  0.00%   0 CEF process
  54           4         2       2000  0.00%  0.00%  0.00%   0 CCVPM_HDSPRM
  55           0         1          0  0.00%  0.00%  0.00%   0 Router Autoconf
  56           8         1       8000  0.00%  0.00%  0.00%   0 TSP
  57           4         1       4000  0.00%  0.00%  0.00%   0 QOS_MODULE_MAIN
  58           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_HTSP
  59           0         1          0  0.00%  0.00%  0.00%   0 CCVPM_R2
  60           0         1          0  0.00%  0.00%  0.00%   0 CCSWVOICE
  61           0         2          0  0.00%  0.00%  0.00%   0 Background Loade
  62           0         1          0  0.00%  0.00%  0.00%   0 sssapp
  63           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
  64        5852    199755         29  0.00%  0.00%  0.00%   0 BUSYOUT SCAN
  65        4892   1996987          2  0.00%  0.00%  0.00%   0 trunk conditioni
  66           0         1          0  0.00%  0.00%  0.00%   0 trunk conditioni
  67      316832    800567        395  0.00%  0.00%  0.00%   0 IP NAT Ager
  68      184200    263667        698  0.00%  0.00%  0.00%   0 IP SNMP
  69      104092    131303        792  0.00%  0.00%  0.00%   0 PDU DISPATCHER
  70      960836    131502       7306  0.00%  0.03%  0.02%   0 SNMP ENGINE
  71           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
  72           8         2       4000  0.00%  0.00%  0.00%   0 SNMP Traps
  73       13096   1998600          6  0.00%  0.00%  0.00%   0 NTP
  74       23868     11160       2138  0.00%  0.00%  0.00%   0 AAA Accounting
  75          68     16655          4  0.00%  0.00%  0.00%   0 DHCPD Timer
  76       40040    566034         70  0.00%  0.00%  0.00%   0 DHCPD Database
Robab,
What exactly did you add?
to the intefaces. they were using cef.
serge123
Have you try removing the ip accounting mac-address under fa 0/1
Robab,
If it were me, personally I would always run CEF if I can, unless you have a reason to otherwise.
I know but since users complain alot and I thought just to give it a try.I removed it now. but again everything is very slow!!
Robab,
Have there been any configuration changes before all the "slowness" started?
Also, can you post the results of 'show processes cpu' again.
You may need to change your load-interfacel from the default of 5 minutes to 'load-inteface 30' under the fast ethernet interfaces to get better idea of what's going on.
Do you have any VPN tunnels on this router by any chance?
Are you able to type the following command and post the rsults
"show int f0/0 switching" "show int fa0/1 switching"
show ip int f0/0 and show ip int f0/1
