Slow throughput on VTI
gchevalley
Recently I have configured a VTI interface between two 2921 routers.  The link between the two routers is 100 Mb but the tunnel doesn't seem to be able to pass that much traffic.  I've noticed some differences between the MTU and bandwidth in the Tunnel interface versus the physical interface.  Is this normal for a VTI?
Tunnel1 is up, line protocol is up
  Hardware is Tunnel
  Internet address is 192.168.193.127/31
  MTU 17862 bytes, BW 100 Kbit/sec, DLY 50000 usec,
     reliability 255/255, txload 43/255, rxload 99/255
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel source 1**.***.***.1, destination 1**.***.***.2
  Tunnel protocol/transport IPSEC/IP
  Tunnel TTL 255
  Tunnel transport MTU 1422 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "RD_VTI")
  Last input 4w2d, output 4w6d, output hang never
  Last clearing of "show interface" counters 4w2d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 176
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  30 second input rate 123000 bits/sec, 157 packets/sec
  30 second output rate 1994000 bits/sec, 233 packets/sec
     836701737 packets input, 47577560492 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     1506226971 packets output, 1926214877370 bytes, 0 underruns
     0 unknown protocol drops
     0 output buffer failures, 0 output buffers swapped out 30 second input rate 123000 bits/sec, 157 packets/sec
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Without deep analysis, your adjust-mss seems overly small; IP MTU less 40 is the common setting.
There are benefits to enabling PMTUD on the tunnel interface (see my earlier Cisco white paper reference).
So what does the shaper at 95% shape at?  Why are you shaping?
7 Replies 7
Joseph W. Doherty
Disclaimer
Posting
Cisco recommends the 2921 for up to 50 Mbps of WAN bandwidth, and also notes 207 Mbps throughput for IPSec.  I.e. 100 Mbps (duplex) might be near the limits of a 2921's performance.
However, IPSec performance can be adversely impacted by fragmentation, something an optimal configuration avoids.
You may find this helpful: http://www.cisco.com/en/US/tech/tk827/tk369/technologies_white_paper09186a00800d6979.shtml
gchevalley
Here is the tunnel config.
policy-map DR
class class-default
  shape average percent 95
crypto isakmp policy 1
encr aes 256
hash sha256
authentication pre-share
group 5
crypto isakmp key 6 address 0.0.0.0
crypto isakmp keepalive 10
crypto ipsec transform-set ESP-AES-ESP-SHA512-HMAC esp-aes esp-sha512-hmac
mode tunnel
crypto ipsec profile RD_VTI
set transform-set ESP-AES-ESP-SHA512-HMAC
interface Tunnel2112
ip address 192.168.193.127 255.255.255.254
ip mtu 1418
no ip route-cache
ip tcp adjust-mss 1300
load-interval 30
tunnel source 1**.***.***.1
tunnel mode ipsec ipv4
tunnel destination 1**.***.***.2
tunnel protection ipsec profile RD_VTI
service-policy output DR
interface GigabitEthernet0/1
ip address 1**.***.***.1 255.255.255.252
no ip route-cache
duplex full
speed 100
Disclaimer
Posting
Thanks for the white paper, it's been helpful.
Shaping at 95% shapes bassed on the interface bandwidth.  When I configured that I was under the impression that it would use the physical interface bandwidth but now do not believe that is the case.
I used the following white paper as a guide for the configuration and is where the idea of the service policy came from:
http://www.cisco.com/en/US/technologies/tk583/tk372/technologies_white_paper0900aecd8029d629_ps6635_Products_White_Paper.html
Disclaimer
Posting
You would normally only need to shape if there was a lower logical cap.  For example, your hand-off was gig but with a 100 Mbps logical cap.
If you have full 100 Mbps, and your interface is also 100 Mbps, no need to shape.
I have change the MTU size to 1422 and the MSS to 1382 with great success.  I configured PMTUD for a bit but some of our Oracle servers seemed to have some problems with it so I had to that command.
Thanks for the help.
Thanks for letting us know.
