The cost effective Branch router
MrBeginner
Dear all,
I would like to request to suggest to choose for branches router between isr 1000 and isr 4300.
My requirement is IPSec 100 M support. i will run DMVPN for spoke Tunnel and other Point to Point IPSec Tunnel.So i run two tunnel in one branches router.
Which model is cost effective and can good performance ?
shaps
Level 3
Level 3
Both can do what is required, the 4321 is what I have used in the past and it can go up to 100 Mbps encrypted with licensing.
Not sure about the ISR 1000, you will need to check the specs,
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html#Platform-Architecture-and-Capabilities
shaps
Level 3
Level 3
