Span Port
JASON NIELSEN
Here is my config.
interface GigabitEthernet1/0/1
description RECORDING_SERVER
switchport access vlan 110
switchport mode access
spanning-tree portfast
monitor session 1 source vlan 110 - 121
monitor session 1 destination interface Gi1/0/1 ingress untagged vlan 110
I have a recording server to record voice calls, but it only works to certian VLANS. It does not work to our voice gateways that are in VLAN 110.
Any suggestions would be greatly appreciated.
TIA
sourabhagarwal
Level 4
Level 4
is it not working only for 110 out of 110-121 VLANs?
I'm not sure as why you are using "untagged vlan 110 " in monitor session 1 destination command.
maybe you can check by configuring below and see it it works for you.
no monitor session 1
hope to help ... rate if it does ...
the last line
monitor session 1 destination interface gi1/0/1 ingress
will not accept a
the options are dot1q, isl, untagged and vlan with more options.
my first config to me looks correct.
Edison Ortiz
Try this option
monitor session 1 destination interface Gi1/0/1 encapsulation replicate
