speed issues.
nagasheshu2010
Hi Friends,
Please advice on below.
We have a customer who has taken 100 Meg internet line.
There is a managed switch (l2) in customer location, switch details are.
WS-C2960S-24TS-S
(C2960S-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Port Gi0/1 connects to customer firewall and had below configuration.
interface GigabitEthernet0/1
description 100Mb internet
switchport access vlan 262
speed 100
duplex full
no cdp enable
spanning-tree bpdufilter enable
spanning-tree guard root
They have this line since 4 years appx and they were getting purchased speed for quite a long time.
Recently, we have migrated our core, we migrated from C7300-JS-M to ASR1004. Since then they started raising concerns on speed that they are not getting expected speed (they were getting 60-70 when tested on speedtest.com)
I took up the call, had a brief investigation and changed the speed and duplex of managed switch interface Gi0/1 to 1000 and full.
speed 1000
duplex full
no cdp enable
end
They started getting assigned speed (close to 100)
Customer would like to know the reason why suddenly this has happened when it was working on 100/full for so long time.
FYI - There has been no changes at customer end, physically or logically.
Can someone please advice?
Sheshu.
Richard Burts
There are some things in your explanation that I do not understand. You tell us that Gig0/1 connects to the firewall. And you tell us that you have changed the core. And you tell us that when you changed the speed of Gig0/1 that it solved the problem.
If Gig0/1 connected to the core that changed I could understand what happened. Your explanation implies that the firewall did not change. But something about the connection of the switch port Gig0/1 must have changed because changing the speed of the interface solved the issue.
Rick
Rick
