06-22-2023
02:39 PM
- last edited on
09-06-2023
02:13 AM
by
Translator
Hello Cisco's Community.
I have next configuration. I am using FP 1120 as router and firewall for my Netwrok. I configured Bridge Group for my interfaces on FP 1120 via Firepower Device Manager. All my clients receive IPs vid DHPC
192.168.1.0/24
I want to add Static route for network
10.10.10.0/24 via GateWay IP 192.168.1.19
for this I used Routing--> Static Route-->Interface (Use BridgeGroup)--> Networks
(10.10.10.0/24)-->Gateway (192.168.1.19)-->Metric (100)
--> Save --> Deploy. BUT after this operation my Windows Client eg.
192.168.1.5
doesn't receive route from Cisco FP 1120, I checked it use route print, but there is no any route that I have configured on Cisco FP 1120, and , my client
192.168.1.5 cann't connect to 10.10.10.0/24 network via 192.168.1.19 as Gateway
But when I added route manualy
(route add 10.10.10.0/24 Mask 255.255.255.0 GW 192.168.1.19)
all is fine and my client
192.168.1.5
can connect to
network 10.10.10.0/24
Where is the problem ?? Is it in Bridge Group and I must to configure all of this without Bridge Group ??
Thx!
Solved! Go to Solution.
06-24-2023
03:14 AM
- last edited on
09-06-2023
02:34 AM
by
Translator
Well, I have found some informations that point toward this direction. It seems for Routed mode, you must use the BVI as gateway while in transparent mode, you can not specify the BVI as gateway.
Which mean, in your scenario,
192.168.1.1
can not be the gateway to the Windows Box. It must be something else and in your case, you need to use the PfSense as your gateway.
I dont know why you decided by using the firewall in transparent mode but you need to understand by doing that, the firewall will not be your gateway for the traffic comming from the inside network.
In routed mode, you must specify the BVI as the gateway; you cannot specify the member interface.
"In transparent mode, do not specify the BVI IP address as the
default gateway
for connected devices; devices need to specify the router on the other side of the Firepower device as the
default gateway
But, if you ever need to add a static route on the firewall in transparent mode, you need to use a bridge group member as the gateway and not the BVI.
Instead of:
S 10.10.10.0 255.255.255.0 [1/0] via 192.168.1.19, inside_bridge_group
If should be:
S 10.10.10.0 255.255.255.0 [1/0] via 192.168.1.19, inside_1_x
In transparent mode, static routes must use the bridge group member interface as the gateway; you cannot specify the BVI.
06-24-2023 05:44 AM
Hey there
Ok, BUT My FP 1120 configured in Routed Mode not Transparent !
06-24-2023
06:11 AM
- last edited on
09-06-2023
02:35 AM
by
Translator
If you setup the
192.168.1.1 as gateway
for Windows, can you use the internet or access resources ou the outside interface?
06-24-2023
06:26 AM
- last edited on
09-06-2023
02:36 AM
by
Translator
Yes, I cant use Internet via outside interface, and Yes I can access resources of the outside interface. and ONE MORE all clients in
192.168.1.0/24 use FP 1120 192.168.1.1 as Gateway
they receive this options via DHCP which configured on the
FP 1120 (192.168.1.1)
06-24-2023
06:51 AM
- last edited on
09-06-2023
02:37 AM
by
Translator
Got it.
It seems the firewall is not routing back the packet on the same interface it received.
I did a lab on the PacketTracert, which is very limited in many functionality, but the result is the same. If I use the firewall as gateway for the machine and try to send the packet back to
network 192.168.1.0
it does not work.
Might be some trick or it can not be possible.
06-24-2023 07:02 AM
There is a similar thread here in the forum with a proposal solution
You may take a look
06-24-2023 09:18 AM
Ok, check. Thx, but it doesn't work for me.
06-22-2023
03:40 PM
- last edited on
09-06-2023
02:38 AM
by
Translator
FPR is assign IP to client as
dhcp
server?
06-22-2023
11:08 PM
- last edited on
09-06-2023
02:38 AM
by
Translator
Yes, FPR is assign IP to client as
DHCP
Server
06-23-2023
03:39 AM
- last edited on
09-06-2023
02:39 AM
by
Translator
I not sure I understand your issue here' but I think you missing config BVI (bridge group interface)
This BVI is ROUTING traffic from bridge group to other router port in FPR' and you can use it as
next-hop
for any static route toward FPR
06-23-2023
05:10 AM
- last edited on
09-06-2023
02:41 AM
by
Translator
Hey. Yes sorry for My mistake:
The Box
192.168.1.19
is pfSense firewall for another network. And it has two interfaces:
WAN - 192.168.1.19 received ip via DHCP from FP 1120 192.168.1.1 - FP 1120 is Gateway for all network 192.168.1.0/24
and I have already configured pfSense (add NAT and Firewall rules) and its work because I can ping machine behind pfSense LAN
so I have only ONE problem, why my static route on FP 1120 doesn't route traffic from
192.168.1.0/24
when boxes asking
? Are U understandt me ?
06-23-2023
05:11 AM
- last edited on
09-06-2023
02:43 AM
by
Translator
can I see
show ip interface
show route
of FPR
06-23-2023 05:46 AM
show route
Gateway of last resort is 10.9.61.1 to network 0.0.0.0
S* 0.0.0.0 0.0.0.0 [1/0] via 10.9.61.1, outside
C 10.9.61.0 255.255.255.0 is directly connected, outside
L 10.9.61.70 255.255.255.255 is directly connected, outside
C 192.168.1.0 255.255.255.0 is directly connected, inside_bridge_group
L 192.168.1.1 255.255.255.255
show ip
System IP Addresses:
Interface Name IP address Subnet mask Method
Ethernet1/1 outside 10.9.61.77 255.255.255.0 DHCP
Ethernet1/2 inside_1_2 192.168.1.1 255.255.255.0 manual
Ethernet1/3 inside_1_3 192.168.1.1 255.255.255.0 manual
Ethernet1/4 inside_1_4 192.168.1.1 255.255.255.0 manual
Ethernet1/5 inside_1_5 192.168.1.1 255.255.255.0 manual
BVI1 inside_bridge_group 192.168.1.1 255.255.255.0 manual
Current IP Addresses:
Ethernet1/1 outside 10.9.60.70 255.255.255.0 DHCP
show interface
Interface Ethernet1/1 "outside", is up, line protocol is up
Hardware is EtherSVI, BW 1000 Mbps, DLY 10 usec
MAC address 4006.d585.ffa4, MTU 1500
IP address 10.9.61.70, subnet mask 255.255.255.0
Traffic Statistics for "outside":
2000330 packets input, 1869946741 bytes
1196265 packets output, 250871661 bytes
69511 packets dropped
1 minute input rate 128 pkts/sec, 100091 bytes/sec
1 minute output rate 91 pkts/sec, 14058 bytes/sec
1 minute drop rate, 1 pkts/sec
5 minute input rate 315 pkts/sec, 385572 bytes/sec
5 minute output rate 180 pkts/sec, 55798 bytes/sec
5 minute drop rate, 1 pkts/sec
Interface Ethernet1/2 "inside_1_2", is up, line protocol is up
MAC address 4006.d585.ffa5, MTU 1500
IP address 192.168.1.1, subnet mask 255.255.255.0
Traffic Statistics for "inside_1_2":
1096507 packets input, 196343029 bytes
1542111 packets output, 1392885898 bytes
46053 packets dropped
1 minute input rate 40 pkts/sec, 7019 bytes/sec
1 minute output rate 85 pkts/sec, 88498 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 177 pkts/sec, 50267 bytes/sec
5 minute output rate 298 pkts/sec, 366006 bytes/sec
Interface Ethernet1/3 "inside_1_3", is up, line protocol is up
MAC address 4006.d585.ffa6, MTU 1500
Traffic Statistics for "inside_1_3":
366301 packets input, 91774084 bytes
624295 packets output, 528602471 bytes
12822 packets dropped
1 minute input rate 67 pkts/sec, 9467 bytes/sec
1 minute output rate 97 pkts/sec, 76422 bytes/sec
5 minute input rate 19 pkts/sec, 13982 bytes/sec
5 minute output rate 31 pkts/sec, 27899 bytes/sec
5 minute drop rate, 0 pkts/sec
Interface Ethernet1/4 "inside_1_4", is down, line protocol is down
MAC address 4006.d585.ffa7, MTU 1500
Traffic Statistics for "inside_1_4":
0 packets input, 0 bytes
0 packets output, 0 bytes
31170 packets dropped
1 minute input rate 0 pkts/sec, 0 bytes/sec
1 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute input rate 0 pkts/sec, 0 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
Interface Ethernet1/5 "inside_1_5", is down, line protocol is down
MAC address 4006.d585.ffa8, MTU 1500
Traffic Statistics for "inside_1_5":
Interface Ethernet1/6 "", is admin down, line protocol is down
Available but not configured via nameif
Interface Ethernet1/7 "", is admin down, line protocol is down
Interface Ethernet1/8 "", is admin down, line protocol is down
Interface Ethernet1/9 "", is admin down, line protocol is down
Interface Ethernet1/10 "", is admin down, line protocol is down
Interface Ethernet1/11 "", is admin down, line protocol is down
Interface Ethernet1/12 "", is admin down, line protocol is down
Interface Management1/1 "diagnostic", is up, line protocol is up
Hardware is en_vtun rev00, BW Unknown Speed-Capability, DLY 1000 usec
Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
Input flow control is unsupported, output flow control is unsupported
MAC address 4006.d585.ff81, MTU 1500
IP address unassigned
38992 packets input, 13335264 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops, 0 demux drops
109 packets output, 64310 bytes, 0 underruns
0 pause output, 0 resume output
0 output errors, 0 collisions, 12 interface resets
0 late collisions, 0 deferred
0 input reset drops, 0 output reset drops
input queue (blocks free curr/low): hardware (0/0)
output queue (blocks free curr/low): hardware (0/0)
Traffic Statistics for "diagnostic":
0 packets dropped
Management-only interface. Blocked 0 through-the-device packets
Interface BVI1 "inside_bridge_group", is up, line protocol is up
MAC address N/A, MTU 1500
Traffic Statistics for BVI1:
117733 packets output, 3464219 bytes
0 packets dropped
1 minute output rate 1 pkts/sec, 55 bytes/sec
5 minute output rate 1 pkts/sec, 60 bytes/sec
06-23-2023 06:02 AM
06-23-2023
07:05 AM
- last edited on
09-06-2023
02:45 AM
by
Translator
Sorry it not clear but
Pfsense and FPR and clinet share same subnet
192.168.1.0/24
The client use
gw push via dhcp'
Now subnet
10.10.10.0/24 from fpr can reach via default route'
Are this correct until here ?
The only thing make issue here is client dont have correct gw (it must be fpr IP) or the subnet is incorrect between dhcp network and fpr interface IP.
