Static Route for Bridge Group on FP 1120
Derek1993
Hello Cisco's Community.
I have next configuration. I am using FP 1120 as router and firewall for my Netwrok. I configured Bridge Group for my interfaces on FP 1120 via Firepower Device Manager.  All my clients receive IPs vid DHPC
192.168.1.0/24
I want to add Static route for network
10.10.10.0/24 via GateWay IP 192.168.1.19
for this I used Routing--> Static Route-->Interface (Use BridgeGroup)--> Networks
(10.10.10.0/24)-->Gateway (192.168.1.19)-->Metric (100)
--> Save --> Deploy. BUT after this operation my Windows Client eg.
192.168.1.5
doesn't receive route from Cisco FP 1120, I checked it use route print, but there is no any route that I have configured on Cisco FP 1120, and , my client
192.168.1.5 cann't connect to 10.10.10.0/24 network via 192.168.1.19 as Gateway
But when I added route manualy
(route add 10.10.10.0/24 Mask 255.255.255.0 GW 192.168.1.19)
all is fine and my client
192.168.1.5
can connect to
network 10.10.10.0/24
Where is the problem ?? Is it in Bridge Group and I must to configure all of this without Bridge Group ??
Thx!
40 Replies 40
Just check the gw of windows client' it is point to FPR or pfsense ?
Hey There
U don't understand me correct:
pfSense has two interfaces:
WAN - connect to my home network 192.168.1.0/24 and receive IP 192.168.1.19
also pfSense Has another interface
LAN - its 10.10.10.0/24
and after my configuration My windows machine receive GW as
FP 1120 192.168.1.1 !
Never Mind,
the windows have GW which is FPR bridge IP, the windows send packet to
10.10.10.0
the pfsense send back traffic direct to host.
This traffic is drop via FPR because it see half traffic, this asymmetric traffic drop behavior is issue,
the solution is  NATing the traffic
NATing traffic to OUTside if the destination is
10.10.10.0
then add
static route to 10.10.10.0
toward pfsense IP.
add static route in pfsense of OUTside subnet toward bridge IP.
Ok, so You mean add all this configuration on
pfSense 192.168.1.19
if Yes - I have already done all this steps, that's why if I add manual route to my windows machine like this
route add 10.10.10.0 MASK 255.255.255.0 GW 192.168.1.19
(pfSense WAN interface)...
check my comment again,
there is asymmetric traffic and because of that FPR drop the packet, this not relate to you use BVI in static route in FPR.
client-FPR-pfSense
pfSense-client
you see FPR is missing in return path,
BUT if you add static route in Win the traffic will be
client-Pfsense
Pfsense-client
that why it work with adding static route in Win,
solution as I mention above you need NATing which make both path pass through FPR.
Pfsense and FPR and clinet share same
subnet 192.168.1.0/24
Yes pfSense and FP 1120 on the same
The client use
gw push via dhcp
Yes Clients receive GW via DHCP from FP and the gateway for pfSense and Windows Box is
FP 1120 - 192.168.1.1
The only thing make issue here is client dont have correct gw (it must be fpr IP) or the subnet is incorrect between dhcp network and fpr interface IP. - No, client has correct IP as
GW FP 192.168.1.1
subnet is correct.. Any ideas ??
The Pfsense share same subnet with fpr and client ? Why you use this topolgy if the gw is fpr ?
Derek1993
@Flavio Miranda @MHM Cisco World
So I think the main problem: that I use BVI (bridge virtual interface) and I don't why but static route doesn't work... I make some testing and give You feedback. Any ideas before my testing ??
Your main problem is the fact that you have both source and destination on the same interface. If you connect you PfSense in a different interface on the ASA all your problems goes alway.
  Beside the fact that ASA needs to receive the packet and sent if back on the same interface, which is not a normal situation, as routed firewall is basically a router, you still have the problem that the PfSense has direct connectivity with the Windows Box plus creating  more routing problem.
 Which means, your topology is not good and you must have a very good justification to keep that way  but, looking  from outside, I´d say you should consider re-design your network on this point.
Yes, Your are correct.. Go to make new networking...Thx a lot for your support, after change my network I return to You and give some feedbacks
Derek1993
Thx all. The solution - change from Virtual Bridge Group Interface, to deafult interfaces and all static routes work very well !
Thx to ALL
