ASR 10002-X IOS upgrade problem TFTP timing out
Steve Coady
Hello
I have TFTP server running
I can ping between router and laptop
Both interfaces are hard coded for gig/full
There is (6001291264 bytes free) on ASR
Image is asr1002x-universalk9.03.12.01.S.154-2.S1-std.SPA.bin (401,851kb)
I use copy tftp: bootflash: command
ASR1002x#copy tftp: bootflash:
Address or name of remote host []? 1.1.1.2
Source filename []? asr1002x-universalk9.03.12.01.S.154-2.S1-std.SPA.bin
Destination filename [asr1002x-universalk9.03.12.01.S.154-2.S1-std.SPA.bin]?
Accessing tftp://1.1.1.2/asr1002x-universalk9.03.12.01.S.154-2.S1-std.SPA.bin...
%Error opening tftp://1.1.1.2/asr1002x-universalk9.03.12.01.S.154-2.S1-std.SPA.bin (Timed out)
MMC-ASR1002x#
Please provide some expert guidance on how to resolve this.
sMc
Marc Faggion
Very difficult to say without further debugging, but one thing that does spring to mind is the management VRF on the ASR. If you are using the Gig0 interface on the ASR, make sure that you have the config listed at:
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/Management_Ethernet.html#wp1065360
Marc Faggion
mfaggion
Thank you for the response. May best to just use the management int, gi0, for this?
I am currently using Gi0/0/5
sMc
