switch, router and vlans
Manish Manwal
hi all,  i had set two users in cisco 3850 and 3650 -i switch. one is admin with privilege 15 and another is user with privilege 7.
but when we login from admin user it is not asking for enable password, it directly goes to privilege exc mode. i have set enable secret level 15 but its can' t work. so pleas guide me how set enable password for user who has privilege 15.
THANKS
MANISH MANWAL
14 Replies 14
Deepak Kumar
Share your Line VTY configuration.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
mr deepak
username user password 7 106
username Admin privilege 15 password 7 0123565B4846
ine con 0
 login local
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login
THANKS
MANISH MANWAL
This is becuase " Level 15 is the level of access permitted by theenable password."
Deepak Kumar
Deepak Kumar,
sir, how i can set enable password for that.
how to stop admin to goes directly to privilege exec.
THANKS
MANISH MANWAL
Try with below configuration.
aaa new-model
aaa authentication login default group radius local
line vty 0 4
no login local
login authentication default
try this command along with your username and password.
Deepak Kumar
Deepak Kumar,
I have try this but it cant work.
THANKS
MANISH MANWAL
Hello!
Can you try using this commands?
S(config)#line vty 0 15
S(config-line)#login local
S(config-line)#priviledge level 0
Best Regards,
Mam i have try this also. Its not working mam.
Thanks and Regards
Manish Manwal
9410971954
THANKS
MANISH MANWAL
I tested in my lab and it is working. Please share "Show Version" and full running configuration of the router.
Deepak Kumar
Deepak Kumar,
is it possible to done this without aaa model.
becouse when we crate aaa, it prevent me to login in my switch.
THANKS
MANISH MANWAL
Rajesh Hirani
It is what "Deepak" said. The enable mode gives you right to "level 15". If you try logging in the EXEC mode and check level; you will see "7 or 15" (depending on the credential you use)!!
Cheers
hey mr. rajesh;
 i think you din't get my question. please read this again. if you din't get this, tell me, i am try it an easy language. then please reply helpful suggestion. thank you.
THANKS
MANISH MANWAL
Sorry Manish. May be I misunderstood what you are asking.
hey Mr. rajesh;
 i think you didn't get my question. please read this again. if you didn't get this, tell me, i am try it an easy language. then please reply helpful suggestion. thank you.
THANKS
MANISH MANWAL
