TACACS Issue with IOS image 15.3
Inderjeet Singh
Dear all,
I am facing a Tacacs issue with 15.3 image on 1941 router..
Basically when we ordered new 1941, the default image we got was  c1900-universalk9-mz.SPA.153-1.T1.bin
Now we have two privilege levels configured for different users group on Tacacs.. Level 15 is system engineers and Level 7 for helpdesk engineers.
Below are the privilege 7 commands allowed on router..
privilege exec level 7 traceroute
privilege exec level 7 ping
privilege exec level 7 show startup-config
privilege exec level 7 show running-config
privilege exec level 7 show configuration
privilege exec level 1 show logging
When the system engineer logs into router with Privilege 15, he doesn't get any issue in running any "show" command.. but when a helpdesk engineer logs in, he get below error while running "show" command.
civrixr01_new#sh config
Using 13253 out of 262136 bytes
%Error opening nvram:/startup-config (Permission denied)
When I changed the IOS to c1900-universalk9-mz.SPA.151-4.M7.bin(lower version) .. The error disappeared..
Any Idea if this can be an IOS bug or Tacacs server issue.
pradeepser
Hi Inderjeet,
In that new IOS, configure the file system privilege level through config command "file privilege 7" and check.
Kumar
6 Replies 6
pradeepser
Hi Inderjeet,
Kumar
Hi Pradeep,
Thanks.. I will apply this, check and will confirm..
Thanks..
Inderjeet
Hello
when logged on as the desktop engineer
show privilege
res
Paul
Kind Regards
Paul
Hi Paul,
Here is the output of "show privilege" command
civrixr01_new#show privi
Current privilege level is 7
civrixr01_new#
Hello
looks like the desktop account as define access privileges hence the reason why they cannot perform the show run command
res
Paul
Kind Regards
Paul
Inderjeet Singh
Hi Pradeep,
Thanks.. its working..
Hi Paul,
Appreciate your help as well in sorting this out..
Thanks..
