Tcacas issue
adhityakarthik
I am not able to login to some deives in the network ,we are using ACS sever
erros is pasted below
Username: *****
Password:
% Authentication failed
User Access Verification
Username:
Username: timeout expired!
Can some one help
regd
Adhi
8 Replies 8
royalblues
Level 10
Level 10
Not much info
From the errors, the device does not seem to be setup correctly for Tacacs configuration
Do you have console access ot the device. Can you also check the logs in the ACS server?
Narayan
Thanks for the update
every one are able to access these devices but this is problem is limited on user id and that to only to some devices
Adhi
You need to then look at the ACS configuration..
There may be Per Group Defined Network Access Restrictions configured on the ACS server
Narayan
He is able to login to some of devices in the network, but only to few devices he is not able to login
Adhi
Do you realize that your question cannot be answered with the information that you gave? Here nobody can save you the legwork of checking what is wrong in your network.
Mohamed Sobair
Level 7
Level 7
AS paolo illustrated, u need to provide more info about ur ACS config.
Mohamed
carlos.morillo
Adhi,
Could you provide a [ show run | inc aaa ] from that device?
I know, you can not logon... but perhaps you have an archived configuration or access to the device via snmp?
Also; in your ACS console look at:
Reports and Activity
->Failed Attempts
->Failed Attemps active
should have a reason for the failure.
Carlos
ear All
please find the config of AAA
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login no_tacacs line
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 0 default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa session-id common
logs from Acs server
Failed attempts reports is bloew
External DB account restriction
onemore time i am repaeting only to few dievices login is not happening
Adhi
