Timestamp ping option
lorenzomot
Hello everyone,
i was wondering if there is a method to have a verbose output of the ping with the timestamp related.
As you can see, i mean an output like this:
14:35:43 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=1 ttl=54 time=20 ms
14:35:44 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=2 ttl=54 time=22 ms
14:35:44 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=3 ttl=54 time=19 ms
14:35:45 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=4 ttl=54 time=20 ms
14:35:45 2018-4-24 DST    Reply from 8.8.8.8: bytes=56 Sequence=5 ttl=54 time=20 ms
Unfortunately trying to search in the extend command filed of the ping options, i can't find the way to do that.
Thank you so much for the support.
Bye
Lorenzo
Diana Karolina Rojas
Hello Lorenzo,
I think you can do it, try this way:
ping
Protocol [ip]:
Target IP address: 1.1.1.1
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: 192.168.3.1
Type of service [0]:
Set DF bit in IP header? [no]: n
Validate reply data? [no]: n
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]: timestamp
Please do not forget to rate/mark useful post.
Best Regards,
i tried the way you told:
ping
Protocol [ip]:
Target IP address: 8.8.8.8
Repeat count [5]: 1000
Datagram size [100]: 1400
Number of timestamps [ 9 ]:
Loose, Strict, Record, Timestamp, Verbose[TV]:
Sweep range of sizes [n]:
Sending 1000, 1400-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Packet has IP options:  Total option bytes= 40, padded length=40
Timestamp: Type 0.  Overflows: 0 length 40, ptr 5
  >>Current pointer<<
  Time= 02:00:00.000 summertime (00000000)
Request 0 timed out
Request 1 timed out
Request 2 timed out
Request 3 timed out
Request 4 timed out
Request 5 timed out
Request 6 timed out
Request 7 timed out
Request 8 timed out
Request 9 timed out
Request 10 timed out
The output is not what i wanted.
I don't know what to insert as value Number of timestamps. I left it as the standard (9) but the result is strange. Moreover the ping failed.
Can anyone help me?
Thank you in advance
Lorenzo
