Traffic Distribution
manish-young
Dear All,
I have router with ADSL interface and Serial Interface, how can I route SMTP Traffic from Serial Interface and Internet traffic from ADSL interface
Thanks in advance
Manish
spremkumar
Level 9
Level 9
You can make use of PBR here matching the SMTP traffic using ACL and put them in route-map configuring the next hop ip address via the Serial interface.
Here you can match either using based on the SMTP server ip address or even the port being used for the smtp access.
to also have reduandcy kick in when theres some probs with the main link u can add one more ip in addition to the primary next hop ip so that the SMTP traffic may not get affected if theres some link failure with serial interface.
would suggest to check this link for more info on configuring PBR..
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_configuration_guide_chapter09186a00800ca590.html#4766
regds
leonvd79
Level 4
Level 4
You can use policy based routing by creating a route-map combined with an access-list.
ip access-list extended permitSMTP
permit tcp any any eq smtp
ip access-list standard permitAny
permit any
route-map outboundPolicy permit 10
match ip address permitSMTP
set ip next-hop
route-map outboundPolicy permit 20
match ip address permitAny
set ip next-hop
interface
ip policy route-map outboundPolicy
Thanks guys,
I shall try this
Will update you guys
Manish
