Transparent DSL to Ethernet bridge using AAL5MUX
kayasaman
I'm trying to build a project where I utilize a Cisco 877 as a dumb modem by briding the ATM interface together with an Ethernet interface (VLAN) in this case due L2 switchports.
The online documentation for RFC 2684 bridging states that I should be using AAL5SNAP as the encapsulation mechanism however, my ISP requires that I use the AAL5MUX encapsulation as part of the DSL settings.
My current config looks like so:
Header 1
Building configuration...
Current configuration : 1694 bytes
! Last configuration change at 22:46:28 BST Sun Aug 19 2012 by admin
! NVRAM config last updated at 22:47:41 BST Sun Aug 19 2012 by admin
version 12.4
no service pad
service password-encryption
hostname Cisco877W
boot-start-marker
boot-end-marker
no aaa new-model
clock summer-time BST recurring
no ip routing
no ip cef
username <omitted>
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
pvc 0/38
  encapsulation aal5snap
dsl operating-mode auto
bridge-group 1
interface FastEthernet0
switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
switchport access vlan 3
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
no ip route-cache
interface Vlan2
no ip address
no ip route-cache
bridge-group 1
interface Vlan3
ip address 192.168.1.254 255.255.255.0
no ip http server
no ip http secure-server
access-list 100 permit tcp 192.168.0.0 0.0.1.255 any eq telnet
access-list 100 deny   tcp any any eq telnet
access-list 100 remark Only allow local subnets telnet acces
control-plane
bridge 1 protocol ieee
line con 0
logging synchronous
no modem enable
line aux 0
line vty 0 4
access-class 100 in
logging synchronous
login local
transport input all
scheduler max-task-time 5000
ntp server 192.168.1.120
end
Currently the internet/WAN connectivity is really poor as the system either doesn't connect or connects really slowly and quieries don't get through, pages don't resolve etc...
Prior to this when I was using the 877 in full routing mode with the Dialer sub interface providing the PPPoA connection to my ISP the internet speed was fine unless the line got conjested.
The previous config I was using is as follows:
Header 1
interface ATM0
mtu 1500
no ip address
no ip route-cache
shutdown
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl lom 200
interface Dialer0
ip address negotiated
ip nat outside
no ip virtual-reassembly
encapsulation ppp
no ip route-cache
shutdown
dialer pool 1
no cdp enable
ppp authentication chap callin
ppp chap hostname <omitted>
ppp chap password <omitted>
At present I haved OpenBSD doing PPPoE with NAT/PAT/firewall/routing etc.... on a Sun Microsystems Netra T105 SPARC server. As stated this is a test project to compare speed and capability.
The CPU and memory of the server are not in use at all as there's plenty of juice left inside the system so no reason for routing packets to be bottlenecked by OpenBSD.
Could anyone help me get AAL5MUX working if it is at all possible as I'm positive that this will sort out my internet connectivity issues....??
If I run a quick 'show' from the ATM interface I get a bunch of options and I'm not sure which one I need or even if it is compatible for bridging:
Header 1
(config-if-atm-vc)#encap aal5mux ?
  fr-atm-srv   Frame Relay/ATM service interworking
  frame-relay  Frame Relay/ATM network interworking
  ip           IP
  ppp          VC MUX PPP over AAL5 Encapsulation
  voice        Voice over ATM
(config-if-atm-vc)#encap aal5mux ppp ?
  Virtual-Template  Virtual Template interface
  dialer            pvc is part of dialer profile
Perhaps would I need to create a virtual-template and bridge from there?
5 Replies 5
kayasaman
In  fact with LOM enabled running sh dsl inter I get this:
Header 1
#sh dsl inter
ATM0
Alcatel 20190 chipset information
         ATU-R (DS)            ATU-C (US)
Modem Status:     Showtime (DMTDSL_SHOWTIME)
DSL Mode:     ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:      0x03                 0x2
Chip Vendor ID:     'STMI'                 'GSPN'
Chip Vendor Specific:  0x0000             0x0010
Chip Vendor Country:   0x0F             0xFF
Modem Vendor ID: 'CSCO'                 'GSPN'
Modem Vendor Specific: 0x0000             0x1000
Modem Vendor Country:  0xB5             0xFF
Serial Number Near:    FCZ112713XK
Serial Number Far:
Modem VersChip ID:      C196 (0)
DFE BOM:     DFE3.0 Annex A (1)
Chip ID:      C196 (0)
Capacity Used:     48%                 100%
Noise Margin:     16.5 dB              7.0 dB
Output Power:     20.0 dBm             10.0 dBm
Attenuation:     19.0 dB              7.0 dB
Defect Status:     None                            None
Last Fail Code:     None
Watchdog Counter: 0xDC
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:     12431 (0 spurious)
PHY Access Err:     0
Activations:     3
LED Status:     ON
LED On Time:     100
LED Off Time:     100
Init FW:     init_3.0.010_nobist.bin
Operation FW:     AMR-3.0.010.bin
FW Source:     external
FW Version:     3.0.10
          DS Channel1      DS Channel0    US Channel1      US Channel0
Speed (kbps):              0            8192             0             907
Cells:                  0      1834382523             0      1723611539
Reed-Solomon EC:          0               0             0               0
CRC Errors:              0             597             0               0
Header Errors:              0             439             0               0
Total BER:          0E-0         2354E-10
Leakage Average BER:      0E-0         8322E-12
Interleave Delay:         0               4             0              58
Bitswap:           enabled          enabled
Bitswap success:          0                  0
Bitswap failure:          0                  0
LOM Monitoring : Enabled
LOM watch configured for 200 times
LOM appeared continuously for 0 times
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 0 3 5 7 8 9 A A B
010: C C C C C C C D C C C C B B B A
020: 0 0 0 0 2 2 4 4 4 4 5 6 6 6 6 7
030: 7 7 7 7 7 8 8 8 8 8 8 8 8 8 8 8
040: 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
050: 8 8 8 8 8 8 8 8 8 8 8 8 7 7 8 7
060: 7 7 7 7 7 7 7 7 7 7 7 2 7 8 8 8
070: 7 7 7 7 7 7 7 8 7 7 7 7 7 7 7 8
080: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
090: 7 7 7 7 7 7 7 6 7 7 6 6 6 6 6 7
0A0: 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6
0B0: 6 6 6 6 6 6 6 6 6 7 7 7 7 7 7 7
0C0: 7 7 6 7 6 6 6 6 6 6 6 6 6 6 6 6
0D0: 6 6 5 2 2 6 6 6 6 6 6 6 6 6 6 6
0E0: 6 5 6 6 6 6 6 6 6 6 5 5 5 5 6 5
0F0: 5 6 6 7 6 6 6 5 6 6 6 6 5 5 6 6
100: 6 6 6 6 6 6 6 6 6 6 6 4 6 6 6 6
110: 6 6 6 6 6 6 5 6 5 5 4 6 5 6 5 5
120: 5 5 6 6 5 5 5 5 5 5 5 5 5 5 5 5
130: 5 5 5 5 5 5 4 4 4 5 4 4 4 4 4 4
140: 4 4 4 4 4 4 4 4 4 4 5 5 4 5 5 5
150: 5 5 2 4 5 4 5 4 4 5 5 5 5 5 5 4
160: 4 4 4 4 4 4 4 0 4 4 4 4 4 4 4 4
170: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
180: 4 0 4 4 4 4 4 4 4 4 4 4 4 4 4 4
190: 0 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
1A0: 4 0 4 4 4 4 4 4 3 3 3 0 0 0 2 0
1B0: 0 0 2 2 2 2 2 2 0 2 2 2 2 2 2 2
1C0: 0 2 2 2 0 2 2 2 0 0 2 0 2 2 2 2
1D0: 0 0 2 2 2 2 2 2 2 2 0 2 2 2 2 2
1E0: 2 2 2 1 1 0 0 0 0 0 0 0 0 0 0 0
1F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
paolo bevilacqua
Trying to bridge will only produce trouble and poor performances.
Use routing, and everything will work fine.
Giuseppe Larosa
Hello Kayasaman,
AAL5SNAP encapsulation includes a SNAP header that allows to identify the payload as bridged ethernet frames, AAL5MUX does not provide this capability.
As a result of this your attempt to bridge over AAL5MUX  has very poor performance.
As already suggested by Paolo move back to a routed solution.
Hope to help
Giuseppe
Giuseppe Larosa wrote:
Hello Kayasaman,
Yes, altough in theory, both bridged frame over aal5mux, or bridged frame over ppp over aal5mux should work.
But as they say, in theory, theory and practice are the same thing, but in practice, they are not.
so sorry for the late response.
I totally lost track of this posting as things got out of control busy :-(
Thanks for the reponses in the meantime!
Hmm.... so any type of ATM to Ethernet bridging will result in poor performance.
Currently having a working system in place with this config:
Header 1
interface ATM0
mtu 1454
no ip address
no ip route-cache
pvc 0/38
dsl lom 200
bridge-group 1
interface Vlan2
no ip address
ip mtu 1454
no ip route-cache
bridge-group 1
Confirming I get:
Bridge Group 1:
    Address       Action   Interface       Age   RX count   TX count
0030.881e.efee   forward   ATM0              0  361151454  220767492
000f.e213.eec0   forward   ATM0              0     863456          0
0800.20f9.c324   forward   Vlan2             0  262447407  425575101
Though too many bit errors:
Header 1
ATM0
Serial Number Far:
Chip ID:      C196 (0)
Capacity Used:     47%                 100%
Noise Margin:     21.5 dB              7.5 dB
Watchdog Counter: 0x57
Watchdog Resets: 0
Subfunction:     0x00
Interrupts:     12536 (0 spurious)
PHY Access Err:     0
Activations:     2
LED Status:     ON
LED On Time:     100
LED Off Time:     100
FW Source:     external
FW Version:     3.0.10
Speed (kbps):              0            8192             0             903
Cells:                  0      1118853068             0      2910286709
CRC Errors:              0             782             0               0
Header Errors:              0             334             0               0
Total BER:          0E-0         2329E-11
Leakage Average BER:      0E-0         4018E-12
With all other PPP config, NAT/PAT, Firewall, static/dynamic routing functions handled by the OpenBSD server.
A few things I've noticed/observed. I do manage to get full ADSL 2+ Annex A performance; between 600 - 700 kbps max downstream bandwidth.
For sure the OpenBSD box is only 400MHz SPARC and only 1 of them meaning that any additional processing would also be going through the single core/socket CPU. It's actually quite interesting to see how say remotely logging in via SSH affects the WAN performance.
Multi user access is also slow and difficult since the bandwidth rapidly drops when 2+ people browse HTTP at the same time, let alone backend services such as web/mail servers.
Also the VoIP system goes completely dead if say someone is loading a video file from eg. Youtube.
I think I'm going to fork out for a Cisco 887VA so that I can utilize the Annex M capability of my DSL line however, the Cisco NAT seems to take lots of memory in the routers.....
My 1801W which I used previously kept crashing once the number of connections went up. Doing a sh ip nat translations and piping the output into a file resulted in roughly 7000+ lines (translations) so no wonder the boxes crash on me all the time.
Luckily I don't have this problem with OpenBSD on the server/router test that I've devised. However, I think I really need a faster internet line/Metro Ethernet compatible router - budget doesn't allow so I guess I'm slightly stuck.
The good part is that I have learned a lot by connecting my various 8xx + 1800 routers to the OpenBSD box using GRE over IPSEC, OSPF, PPPoE etc... and have had the chance to check out SPI and other security features which slowdown/blowup my Cisco boxes.
