Cisco 2600 ADSL Static IP Issue
williamtwomey
I'm coming from a Cisco 837 with a static IP to a 2600 with a ADSL WIC. Same ISP, just moving to new equipment
I have debugging turned on, and get an IP and route from my ISP (AT&T) but when I try to use my static IP I do not get connectivity (and the PPP logs show a completely different route from my ISP than I should be getting statically)
Was hoping someone could take a look at my config and give me some suggestions as to why my static IP doesn't work, but using the following does work:
ip address negotiated
ip route 0.0.0.0 0.0.0.0 Dialer0
[code]
version 12.4
service password-encryption
hostname SL2600
boot-start-marker
boot system flash:c2600-advipservicesk9-mz.124-19.bin
boot-end-marker
enable secret <SNIP>
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip domain name domain.net
ip name-server 4.2.2.2
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vpdn enable
vpdn-group 1
username admin privilege 15 secret 5 <SNIP>
interface ATM0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
bundle enable
dsl operating-mode auto
hold-queue 224 in
interface ATM0/0.1 point-to-point
pvc 0/35
  pppoe-client dial-pool-number 1
interface FastEthernet0/0
ip address 10.10.10.201 255.255.255.0
duplex auto
speed auto
interface ATM0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Dialer0
description WAN
ip address <MY STATIC IP> 255.255.255.248
ip access-group INPUT_ACL in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname user@static.sbcglobal.net
ppp chap password 7 <SNIP>
ppp pap sent-username <SNIP>@static.sbcglobal.net password 7 <SNIP>
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 <STATIC ROUTE>
no ip http server
no ip http secure-server
ip nat inside source list NAT_ACL interface Dialer0 overload
7 Replies 7
paolo bevilacqua
If with negotiated you're getting 'your' address, then all is good.
If not, complain to ISP.
johnlloyd_13
Level 9
Level 9
You've forgot to define your inside NAT interface.
int f0/0
ip nat inside
Kindly test again and revert the results.
Thanks for the response guys.
The NAT issue isn't relevant in this case unfortunately, although I have added that now.
It doesn't appear to be an ISP issue because the 837 works just fine using the static IP. The Dialer0 config is taken straight from the 837.
Try again to contact your ISP. A static WAN IP is usually applied under the ATM interface. Your config clearly shows a dynamic broadband setup using PPPoE.
Thanks for your help, I'll do that.
Could you reference me a config that puts static IP under ATM0 interface? Every config I've seen for a static IP has been under Dialer0.
Below is some debugging output, maybe it will help: (The 76.249.179.X IP is the static IP I have historically been able to use)
*Aug 12 01:13:26.897: Vi2 PPP: Treating connection as a callout
*Aug 12 01:13:26.897: Vi2 PPP: Session handle[12000020] Session id[0]
*Aug 12 01:13:26.897: Vi2 PPP: Phase is ESTABLISHING, Active Open
*Aug 12 01:13:26.901: Vi2 PPP: Authorization required
*Aug 12 01:13:26.901: Vi2 PPP: No remote authentication for call-out
*Aug 12 01:13:26.901: Vi2 LCP: O CONFREQ [Closed] id 1 len 10
*Aug 12 01:13:26.901: Vi2 LCP:    MagicNumber 0x14131518 (0x050614131518)
*Aug 12 01:13:26.901: %LINK-3-UPDOWN: Interface Virtual-Access2, changed state p
*Aug 12 01:13:26.949: Vi2 LCP: I CONFREQ [REQsent] id 195 len 18
*Aug 12 01:13:26.949: Vi2 LCP:    MRU 1492 (0x010405D4)
*Aug 12 01:13:26.949: Vi2 LCP:    AuthProto PAP (0x0304C023)
*Aug 12 01:13:26.949: Vi2 LCP:    MagicNumber 0x5BDB971A (0x05065BDB971A)
SL2600#
*Aug 12 01:13:26.953: Vi2 LCP: O CONFNAK [REQsent] id 195 len 8
*Aug 12 01:13:26.953: Vi2 LCP:    MRU 1500 (0x010405DC)
*Aug 12 01:13:26.953: Vi2 LCP: I CONFACK [REQsent] id 1 len 10
*Aug 12 01:13:26.953: Vi2 LCP:    MagicNumber 0x14131518 (0x050614131518)
*Aug 12 01:13:27.001: Vi2 LCP: I CONFREQ [ACKrcvd] id 196 len 18
*Aug 12 01:13:27.001: Vi2 LCP:    MRU 1500 (0x010405DC)
*Aug 12 01:13:27.001: Vi2 LCP:    AuthProto PAP (0x0304C023)
*Aug 12 01:13:27.001: Vi2 LCP:    MagicNumber 0x5BDB971A (0x05065BDB971A)
*Aug 12 01:13:27.001: Vi2 LCP: O CONFACK [ACKrcvd] id 196 len 18
*Aug 12 01:13:27.005: Vi2 LCP:    AuthProto PAP (0x0304C023)
*Aug 12 01:13:27.005: Vi2 LCP:    MagicNumber 0x5BDB971A (0x05065BDB971A)
*Aug 12 01:13:27.005: Vi2 LCP: State is Open
*Aug 12 01:13:27.005: Vi2 PPP: No authorization without authentication
*Aug 12 01:13:27.005: Vi2 PPP: Phase is AUTHENTICATING, by the peer
*Aug 12 01:13:27.005: Vi2 PAP: Using hostname from interface PAP
*Aug 12 01:13:27.005: Vi2 PAP: Using password from interface PAP
*Aug 12 01:13:27.005: Vi2 PAP: O AUTH-REQ id 1 len 47 from "terminamorte@static"
*Aug 12 01:13:29.121: Vi2 PAP: I AUTH-ACK id 1 len 5
*Aug 12 01:13:29.121: Vi2 PPP: Phase is FORWARDING, Attempting Forward
*Aug 12 01:13:29.121: Vi2 PPP: Queue IPCP code[1] id[201]
*Aug 12 01:13:29.125: Vi2 PPP SSS: Receive SSS-Mgr Connect-Local
*Aug 12 01:13:29.125: Vi2 PPP: Phase is ESTABLISHING, Finish LCP
*Aug 12 01:13:29.125: Vi2 PPP: Phase is UP
*Aug 12 01:13:29.125: Vi2 IPCP: O CONFREQ [Closed] id 1 len 10
*Aug 12 01:13:29.129: Vi2 IPCP:    Address 76.249.179.X (0x03064CF9B391)
*Aug 12 01:13:29.129: Vi2 PPP: Process pending ncp packets
*Aug 12 01:13:29.129: Vi2 IPCP: Redirect packet to Vi2
*Aug 12 01:13:29.129: Vi2 IPCP: I CONFREQ [REQsent] id 201 len 10
SL2600#
SL2600#
*Aug 12 01:13:29.129: Vi2 IPCP:    Address 99.143.127.254 (0x0306638F7FFE)
*Aug 12 01:13:29.129: Vi2 IPCP: O CONFACK [REQsent] id 201 len 10
*Aug 12 01:13:29.209: Vi2 IPCP: I CONFNAK [ACKsent] id 1 len 10
*Aug 12 01:13:29.209: Vi2 IPCP:    Address 99.143.118.64 (0x0306638F7640)
*Aug 12 01:13:29.209: Vi2 IPCP: O CONFREQ [ACKsent] id 2 len 4
*Aug 12 01:13:29.289: Vi2 IPCP: I CONFNAK [ACKsent] id 2 len 10
*Aug 12 01:13:29.289: Vi2 IPCP:    Address 99.143.118.64 (0x0306638F7640)
*Aug 12 01:13:29.293: Vi2 IPCP: Ignoring unrequested options!
*Aug 12 01:13:29.293: Vi2 IPCP: O CONFREQ [ACKsent] id 3 len 4
*Aug 12 01:13:29.689: Vi2 IPCP: I CONFACK [ACKsent] id 3 len 4
*Aug 12 01:13:29.689: Vi2 IPCP: State is Open
*Aug 12 01:13:29.693: Di0 IPCP: Install route to 99.143.127.254
*Aug 12 01:13:29.697: Vi2 IPCP: Add link info for cef entry 99.143.127.254
ksolie
Hi William,
Did you get this working? I have a similar setup and want to run my sbc w/Static on a Cisco 3845 router, not on this moto NVG510 with its limited config they gave me.
But looking through the docs and info from SBC, I have more questions then answers.
I think your config looks good, I don't see a dialer list or the input ACL, but I'm just assuming you left it out. And in this case the layer 3 information always goes under the dialer interface, ip addresses, ACLs, etc.
I've seen a few configs out there using Chap and Pap. From the debugs it looks like pap is what was answered from the carrier.
I'm wondering if because of the PPPoE needed that the only way for the DSLAM to register an address is dynamic. Is the address always the same when you use dynamic?
It seems us people with some statics on DSL are left out in the cold a little, most of the info I'm finding deals with dynamic addresses, including the ppp authentication user/pass.
Please let me know if u got this up and working.  I'm really interested and maybe we can figure it out.
Karl
