Trying to implement Bridge Domain Virtual IP from 8500 to 9300 switch
red2play
Hi, trying to implement a bridge Domain Virtual IP to bridge two diffferent vlans on a port-channel to a switch.
Also,
CorpRoute(config-if)#neg auto
%ERROR: Standby doesn't support this command
the 2nd interface stays down.
Attaching config
pieterh
it has nothing to do with your goal
     "implement a bridge Domain Virtual IP to bridge two diffferent vlans on a port-channel to a switch
some SPF's or interfaces simply do not support "neg auto" -> do not include this command in the converted configuration
if necessary replace with explicit speed/duplex/trunk configuration
Overview (cisco.com)
10G SFP+ on dual-rate 10GE Interface:
Auto-negotiation protocol is not supported, and automatic negotiation cannot be configured using negotiation auto command.
balaji.bandi
what is the version of code - do you have rough digram how these connected ?
BB
