Tunnel from dynamic IP to static IP with authentication
paarlberg
I am looking for an option to do the following.
@home (dyanmic IP)
create tunnel to datacenter router
require authentication for security reasons
dynamically route a /29 or /28 to local network
@dc
Accept tunnel from remote location
route above /29 or /28 over tunnel
Equipment at both locations
@home
Cisco 6509 with SUP2 with MSFC2 full mem
@dc
I would like the cleanest most stable option to allow this to work and still be secure with authentication. I know on the home side, I can just specify the remote ip and add a password. Not sure what can be done on the DC side to allow this to work properly.
paolo bevilacqua
You can configure either a classic IPSEC VPN for that, or Easy VPN.
In either case, you will need cisco routers, not switches.
If you don't know what I'm talking about, hire a professional or certified cisco partner for the configuration.
Yasir Ashfaque
and what about the modules, which modules have you installed ??
paarlberg
I was aware of those options, was just wondering if there were any "better" options.
Modules in the 2 locations are basic, nothing fancy..
@Home
1x 6316-GE-TX
2x 6408A
1x 6348
@DC
4-5x 6408A
1-2x 6348
