two wan connection to Internet
ankyrod2006
I have two connections wan with different ISP, I also have for each connection wan one route. In total I have two router.
As it could achieve traffic balancing with these two connections.
7 Replies 7
royalblues
Level 10
Level 10
You can do load sharing of your traffic by using one wan connection for some subnets and the rest via other connection with fall back between each other.
We can guide with you with the configurations if you can let us know the answers to the following
what is your topology?
where will the NAT be taking place router or firewall?
Narayan
I attach you an image of the design of the network.
my topology is:
ISP1..................ISP2
ROUTER1....ROUTER2
......-SWITCH-
RED INTERNA
I want to know if automatically I can traffic balancing, without making some separation for ISP, because the objective is also, when one ISP is interrupted continued working with the other ISP
Hi Friend,
We can achieve the same using Policy based routing as suggested by Narayan, But this will take a lots of configuration and consideration.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
The best and a long-term solution for this to use a ISP load-balancer. Please see the link below for mofre info:
http://www.radware.com/content/products/lp/default.asp
HTH,Please rate if it does.
-amit singh
Amit,
I was also thinking about RADWARE will be a alternative and easy solution, but only concern I had is whether to suggest radware in a cisco environment or not.
Rajesh
Rajesh,
I have a few of my customers who are running Radware on Cisco devices. They are good so far and solution is working perfectly in their environment.
This box takes a minimum configuration on itself and do the prefect load-balancing of the traffic .
HTH,
-amit singh
Hi, excuse by the delay
There is some technology in similar Cisco to LinkProof of RADWARE ?
greetings
minumathur
You can only do per destination load balanceing, that will do through policy based routig , you can take help from other post which are available in this post.
-Minu
