Showing results forĀ
Search instead forĀ
Did you mean:Ā
unable to do traceroute, ping works.
gavin han
I'm unable to do traceroute, ping works. why is that? using ospf protocol, devices are connected using trunk ports so neighborship is eshtablished using SVI (not L-3 ports). how to fix it?
no ip redirects
no ip unreachables
no ip proxy-arp
no mop enabled
5 Replies 5
Tagir Temirgaliyev
traceroute will not work for example throw gre tunnel
shouldn't traceroute work by default?
trace route is a layer 3 troubleshooting tool if its going across layer 2 trunks its not going to pick anything up , it sounds like you have layer 3 wrapped in layer 2 so trace wont see that as ip is encapsulated
gavin han
could someone advise how to fix this traceroute issue?
what is not working exactly?
Are you trying to traceroute to a Cisco device which has got "no ip unreachables" configured on an L3 interface? It will not reply then.
Or are you trying to traceroute over L2?
You could use
switch#trace mac ?
  H.H.H      48-bit hardware address of source
  interface  Interface on which this source mac exists
  ip         Specify ip addresses
command then.
Best regards,
Milan
