Unable to hit outside interface from outside - Cisco ISR4400
In my current setup I have an ISR4400 directly connected to the ISP. I am able to connect to the internet from the inside and ping any public IP as well as the outside interface IP.. However, I can not ping the outside interface from an outside IP. I am able to ping the next hop router from outside as well.
I have created inside / outside zones and applied the relevant policy and class maps. I also created policies and maps and pairs for the self zone as a test in case for some reason the router was not doing the default behaviour.
For now my class-map refers to an ACL that only allows ICMP from outside to inside.
I saw on another thread about adding a route to the outside interface....is this the issue? If so where is it added as I was unable to add a route outside.
Thanks in advance
orange#show running-config
Building configuration...
Current configuration : 4014 bytes
! Last configuration change at 12:11:21 UTC Mon Apr 16 2018 by xxx
version 15.5
no platform punt-keepalive disable-kernel-core
hostname orange
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$DRvZ$GDXrCeYcWavEfyoHWYH6j.
enable password xxxxxx
aaa new-model
aaa authentication login userauthen local
aaa authorization exec default local
aaa authorization network groupauthor local
aaa session-id common
ip domain name rtr.xxxxxx.com
ip dhcp excluded-address 10.0.25.1 10.0.25.49
ip dhcp pool internal-lan
import all
network 10.0.25.0 255.255.255.0
default-router 10.0.25.1
dns-server 8.8.8.8
domain-name xxxx-xxxx.com
subscriber templating
license udi pid ISR4451-X/K9 sn FOC211587U8
license boot level securityk9
username xxxxx privilege 15 password 0 xxxxxx
redundancy
mode none
vlan internal allocation policy ascending
class-map type inspect match-any outside-inside-class
match access-group name outside-inside-acl
class-map type inspect match-any outside-self-class
match protocol icmp
match protocol https
match protocol http
match protocol dns
match protocol tcp
class-map type inspect match-any self-outside-class
match protocol icmp
match protocol http
match protocol dns
match protocol tcp
class-map type inspect match-any myinspectclass
match protocol http
match protocol tcp
match protocol dns
match protocol icmp
policy-map type inspect self-outside-policy
class type inspect self-outside-class
inspect
class class-default
policy-map type inspect outside-inside-policy
class type inspect outside-inside-class
inspect
class class-default
policy-map type inspect outside-self-policy
class type inspect outside-self-class
inspect
class class-default
policy-map type inspect myinspectpolicy
class type inspect myinspectclass
inspect
class class-default
zone security inside
description LAN
zone security outside
description Internet
zone-pair security in-out source inside destination outside
service-policy type inspect myinspectpolicy
zone-pair security out-self source outside destination self
service-policy type inspect outside-self-policy
zone-pair security outside-to-inside source outside destination inside
service-policy type inspect outside-inside-policy
zone-pair security self-outside source self destination outside
service-policy type inspect self-outside-policy
interface GigabitEthernet0/0/0
ip address 10.0.25.1 255.255.255.0
ip nat inside
zone-member security inside
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
ip address 84.207.207.94 255.255.255.252
ip nat outside
zone-member security outside
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip nat inside source list 100 interface GigabitEthernet0/1/0 overload
ip forward-protocol nd
ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 84.207.207.93
ip scp server enable
ip access-list extended outside-inside-acl
permit icmp any any
access-list 100 permit ip any any
control-plane
line con 0
logging synchronous
stopbits 1
line aux 0
stopbits 1
line vty 0 4
8 Replies 8
rasmus.elmholt
Level 7
Level 7
Are you sure you ISP isn't blocking it for security reasons?
I've been able to hit it before so unless they've changed that policy I would guess not. I've tried other types of traffic besides ICMP such as SSH and that is also not working
Found this in another post "We cannot Inspect a class-map that we matched via a layer 7 protocol/application (We can only inspect layer 4 class-map matches)"
https://supportforums.cisco.com/t5/security-documents/zbfw-self-zone-integration/ta-p/3154572
But they use it in this example along with an ACL:
https://www.cisco.com/c/en/us/support/docs/security/ios-firewall/98628-zone-design-guide.html#accesscontrol
Let me know if it helps.
Dennis Mink
your inspect lists are not the same as access-list you need an access list on your outside interface to allow icmp as well.
Please remember to rate useful posts, by clicking on the stars below.
There are no ACL on the outside interface so everything should be allowed.
I would put one in and maybe do a permit any any or a specific permit icmp from your IP address, you are pinging from so you can at least confirm if the pings are hitting your outside interface
Yes good idea.
Configure an ACL on the outside interface that allows ICMP with the log statement, and rememeber to allow "ip any" as well.
Or maybe do a debug ip packets with an ACL that only allows ICMP. Be carefull if this is a production environment.
Thank you all for the replies so far.
I got frustrated so just wiped the config. I have left the router pinging whilst I add commands to it to see where it is going wrong. It stops replying to ping when I add "IP Nat Outside" to the external facing interface... My NAT set up is a basic:
Do I need to add something for my outside too?
I apologise that I am very much a noob here and there is probably something very obvious!
