Unable to ping between two tunnel points
noforshow92
Hello, I built using the packet tracer a simple topology of three routers with ospf routing. I created a tunnel between the two routers that are not physically connected to each other, but I can't ping between one end and the other. I managed to ping between two in loopbacks.
hanks for all replies.
Router#show run
Building configuration...
Current configuration : 1084 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX152412Z5-
spanning-tree mode pvst
interface Loopback0
ip address 10.10.10.254 255.255.255.0
interface Tunnel0
ip address 100.100.100.10 255.255.255.0
mtu 1476
tunnel source Loopback0
tunnel destination 20.20.20.254
interface GigabitEthernet0/0
ip address 10.0.1.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.0.5.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.0.1.0 0.0.0.255 area 0
network 192.168.1.1 0.0.0.0 area 0
network 100.100.100.0 0.0.0.3 area 0
network 10.0.5.0 0.0.0.255 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
____________________________________________
Router#show run
version 15.1
hostname Router
ip cef
no ipv6 cef
interface Loopback0
interface Tunnel0
mtu 1476
duplex auto
speed auto
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
ip classless
line con 0
line aux 0
line vty 0 4
login
end
20 Replies 20
Hi @noforshow92 ,
I am unable to download the file from this link. Can you please zip the file and upload it here.
yes. attached below
Hi @noforshow92 ,
I made the modification to use the physical interface instead of the loopback interface as recommended previously and it works for me.
Router2:
interface Tunnel0
mtu 1476
tunnel source GigabitEthernet0/0
tunnel destination 10.0.2.1
Router1:
interface Tunnel0
ip address 100.100.100.20 255.255.255.0
mtu 1476
tunnel source GigabitEthernet0/1
tunnel destination 10.0.1.1
Router#ping 100.100.100.10
Sending 5, 100-byte ICMP Echos to 100.100.100.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0/0/0 ms
Router#ping 100.100.100.20
Sending 5, 100-byte ICMP Echos to 100.100.100.20, timeout is 2 seconds:
Thank you very much man!.
It seems like only the port that connected to the third router  can function as a source and destination, any other port on routers does not work with gre vpn, including the loopbacks. is that right?
Another thing, why doesn't my CLI recognize the mtu command?
Router(config)#int tunnel 0
Router(config-if)#mtu
Router(config-if)#mtu?
% Unrecognized command
Hi @noforshow92 ,
I have not done extended testing, but it looks like it is the case.
This command is auto generated and it appears like you can't change it manually.
Bear in mind that Cisco Packet Trace is a network simulation tool and although it does an excellent job at providing a great learning experience, many restrictions in this tool are not present when you use real devices.
AliDoskii
You have to add diagram as well and draw all your ip on interfaces so that we can help you with.
AliDoski
