Unused ports on Switch
gurkamal01
I know my question might seem very simple
Why is it suggested to shutdown unused ports on the switch
and also unused vlans like vlan 1
How soes it pose a security issue in the network
Please reply
i will appreciate any response
Edison Ortiz
- prevents anyone from connecting a switch or hub to your switched network and creating a loop
- prevents any unauthorized workstation from connecting to the network
- add another layer of security
As for the Layer3 Vlans;
- it prevents inadvertently the advertisement of networks
- it preserve switch resources
- another form of network security.
HTH,
__
Edison.
Jon Marshall
Basically if you leave unused ports active someone can wander along to an unused desk etc. and patch in a laptop for example. If you are using DHCP then they would automatically get an IP address.
As for vlans just don't have any unused vlans. Vlan 1 is different. You can't actually shut it down but it is recommended not to have any user ports in vlan 1 as all the management protocols run in this vlan.
Jon
Thanks for the replies
Q1.So how does vlan hoping happen.
Is it related with vlan 1.
Q2. what can happen if i have any unused vlanlike vlan 202
