Upgrading Cisco 1750/1751 Flash Memory, maximum?
azmirccnp
Hi guys,
Need your help on this. Can I know, what is the maximum flash memory capacity can I upgrade on Cisco 1750 & 1751. I need to use minimum 32M of flash memory to upgrade my routers to IOS version 12.3 and up.
And also can I upgrade the memory to 64M? I think there is no problem with the memory upgrade, only concern about the flash upgrade. Especially for 1750 routers.
Thanks.
paolo bevilacqua
as fas as I know, you cannot upgrade flash on the 175x. This is even more an issue when running voice features.
Dennis Wieringa
I would recommend using google or the cisco search function...
FYI:
http://www.cisco.com/en/US/docs/routers/access/1700/1720/hardware/notes/1700UMem.html
And it states that u can upgrade the flash, and the 64mb ram memory upgrade is only supported on the 1751 series and up.
but it doesnt hurt to try
