USB Console Driver install failing
dervari
Running Windows 7 64-bit and the USB driver install is failing.  Well, the setup program runs ok and reboots, but when I connect to a USB console, it installs the Console driver ok but fails on "Cisco Virtual Comm Port00".  I've tried this on multiple machines as administrator and still no joy.
Any ideas?
Thanks!
46 Replies 46
I logged in just to give you 5 stars and say thanks!  This worked perfectly for me on a Win 7 Pro x64 machine.
Thank you, Greg!
Thanks, did doe trick.
Thanks Greg for the instructions and glad that you shared it.
Best regards,
Joao Viegas
I had the same problem.  I followed the steps given and it worked fine.
THANKS!
That worked for me, too.
Thanks Greg - that worked a treat for me.
Thank Greg - saved me from slamming my head against my keyboard (again).
Cheers!
Thanks!!!!
CCNP - Wireless
CWNA
CCNP - Wireless
CWNE #136
Greg is my hero now... I have been fighting this for three days.
Thanks a bunch Greg...
Thanks!!!
snallncmec
Thanks Greg for your excellent instructions!  This worked like a champ!
Thanx Greg, now it works. Can't belive Cisco didn't work it out.
I can't believe Cisco didn't do some basic testing before releasing this.  I spent 30 minutes until I found this article.  Manual pick Cisco Serial fixed it.
Jason Dodge
Thanks!
